I am concerned about toughness in a folder, but my viewpoint is a little different as to what this means.
To me the folder must have a constant spring loaded pressure to stay closed, under any kind of impact or influence: No ball detent failure point beyond which the thing is free to swing open, even if just for one inch of tip travel: That limits me to lockbacks, or pouch knives... Better yet,
both lockback and pouch!
Another point of toughness is not just huge overall strength, which is a given, but the extent to which my hand can apply huge efforts on the blade. Also overall weight can contribute to this if the knife is used as a chopper, if the handle has a "beaked" end that can be used to swing its full length. Most folders today, even large ones, tend to have a rectangular handle section that is fairly narrow or at least angular, no large beaked handle end, and no real built-in guard. For that reason I prefer the Al Mar SERE 3003, even though it is very heavy and has a poor blade to handle ratio (4.25" to 5 7/8").
Many large folders also lack handle depth compared to the Al Mar. The worst thing about the SERE 3003 is the poor edge geometry, but that can be fixed by at least zeroing the edge, or even having a hollow grind added in.
The extremely heavy weight of 11 ounces helps with chopping, but the main advantage is to have a knife that behaves like a fixed blade and yet can be worn horizontally on the belt, not getting in the way of anything else. The oversized handle allows it to do harder cutting more often, with less pain from the repetitive effort on the hand.
Gaston
