Hi all.
I thought I'd put this to the group. How effective would a Wrist Rocket or similar slingshot be as a lightweight hunting and/or defensive weapon? I have seen folding models that wouldn't take up a lot of room. I also seem to recall a little wire attachment on Whammo sling shots which was billed as an "arrow adapter." I like the idea of using te slingshot to propell arrows as well as stones.
I guess if weight and/or space conditions required, simply packing the band or a length of surgical tubing and improvising a slingshot in the field.
That also reminds me of a primative speargun called a "hawaiian sling." Essentially, a spear is drawn back thru a hollow handle, pulling back on surgical rubber bands. (Think of stretching a rubber band over the hole in a spool, then pushing a pencil thru the hole until just the pointed end stickes out). Either a notch trigger is used or the user simply holds the spear in place and lets it go to shoot. (Thats how the Hawaiians did it).
I'm not saying that you should use a spool to propell a pencil, that was just my feeble attempt to explain the mechanics. What do you think of the hawaiian sling as a field-improvised hunting/defensive weapon? How would you modify this concept to make it more effective? How would you fabricate it in the field? Lets see some of this group's legendary creativity and ingenuity!
