Xiaomi Xiaofang Panoramic IP Camera - Dual Lens, Four Split Screen, Support VR
Feedback: +0 / =0 / -0
Xiaomi Xiaofang Panoramic IP Camera uses a large CMOS sensor, bringing 1024 × 2048 HD resolution. Dual lens and double image chips, 360 degrees to monitor your family. You can watch your monitoring video on your phone with 4 screens in a window, two-way audio with your family like at home. F2.0 large aperture lens collocation IR-CUT double filter, plus infrared LED uniform light, maximum night visual distance can be 5m. Come with compact design, 1/4 inch screw hole, built-in G-sensor to meet your needs.
Product Features:
● Front and back dual lens, get a multi-position view with the double shooting camera.
● 1024 × 2048 (1K * 2K) 1080P full high definition resolution provides a clear image.
● Dual lens with dual image sensor to show clear and visible details.
● Four split screen mode, four real-time picture, can be compared with prefessional monitor.
● 850nm infrared night vision without interference, give 5m visual range.
● Built-in microphone and speaker, support two-way remote dialogue.
● Support Android 4.0 and above, iOS 7.0 and above system devices, you can get to know the situation where you want to know by phone or tablet at anytime or anywhere.
● Playback at anytime, in addition to real-time viewing, it can insert a SD storage card to store video for look at any time.
● Dual 360° panoramic view brings a sense of immersive screen, support VR view mode.
● Support panoramic time-lapse photography, so you can reduce hours of the sunrise and sunset to tens of seconds.
● Compact body design, 1/4 inch screw hole, built-in G-sensor.
Only $56.99 needed, then you can get this powerful IP camera from GearVita and know the situation about your home and family at anytime or anywhere: https://gearvita.com/xiaomi-xiaofang-smart-ip-camera.html
Hot sale products:
xiaomi poco f1 lte 64gb smartphone
xiaomi poco f1 lte 128gb smartphone
The Lumintop Geek keychain flashlight born and designed for the enthusiastic pursuit of ultimate craft and superior quality, which combine the multiple technology and functions in an extremely compact size. Aluminum alloy with CNC integrated processing creates a solid and reliable body. Key shape design, compact in size allows one hand easily control. Dual lights lighting with a max 350 lumens output, provides more lighting manners options in your camping, walking, reading or EDC gears etc. Built-in lithium polymer battery and Micro USB charging design allow easy to charge the light without a charger. Battery and charging indicator on the side shows the approximately battery percentage clearly in green, blue or red. Dual switches operation, lock-out function, big key holder, IPX-6 waterproof classification, all these make Geek a masterpiece in the industry.
Main Parameters:
LED: XPL HD (front) + high CRI Nichia (side)
LED Lifespan: 50000h
Color Temperature: 7000K + 4000K
Power Source: Built-in 3.7V/530mAh Li-polymer battery
Peak Beam Distance: 70 meters
Peak Beam Intensity: 1225cd
Waterproof Standard: IPX-6 (water resistant up to 2 meters)
Impact Resistance: 1.5m
Output and Runtime:
● Front Light:
High: 350 lumens ( 30 mins )
Med: 125 lumens ( 1 hours 50 mins )
Low: 25 lumens ( 9 hours 15 mins )
Moonlight: 1 lumen ( 43 hours )
Strobe/SOS/Beacon: 350 lumens ( / )
● Side Light:
▹ Mode 1
High: 350 lumens ( 1 hours 50 mins )
Med: 15 lumens ( 5 hours 40 mins )
Low: 3 lumens ( 18 hours )
▹ Mode 2
High: 5 lumens ( 12 hours )
Low: 1 lumen ( 26 hours )
Eco: 0.2 lumens ( 34 hours )
Product Features:
● Utilizes Cree XP - L HD LED for front light, and high CRI Nichia LEDs for side light with a lifespan of 50000 hours.
● 4 output levels plus Strobe, SOS and Beacon for front light, two modes set for side light to meet your luminous needs in different situations.
● Made of aircraft aluminum alloy with CNC integrated processing, 1.5m impact resistance.
● Autokey structure design, compact and multifunctional.
● Dual switch for one hand operation.
● Micro USB rechargeable with charging indicator, you don't need to buy batteries.
● Built-in 3.7V 530mAh Li-polymer battery, max runtime up to 43h under Moonlight mode.
● Battery level and low power indicator to protect your flashlight from hurts.
● Lock-out function to prevent accidentals activations.
● Can be standing on a flat surface to serve as a reading lamp.
● Waterproof IP-X6, suitable for rainy days.
Classical Ferrari red color highlights its noble and luxury characteristic. Get it on GearVita, not only can it illuminate your night road, but itself can also be used as an ornament on your keychain: https://gearvita.com/lumintop-geek-keychain-flashlight-350-lumens.html
Hot sale products:
xiaomi lyej05lm mini
xiaomi redmi note 5 4g smartphone
The Meizu POP earphone is the first true wireless Bluetooth earphones and wireless charging of Meizu especially designed for sports, no wires for a tangle-free experience. The set comes with a charging case for storage, which features a USB type-C charging, compatible with all mainstream wireless chargers for easy charging. The POP used touch control technology, gently touch to make phone call, adjust volume, make it easier and safer to use.
Product Features:
● Wireless Earphones and Wireless Charging
With no wires for a tangle-free experience, the set comes with a charging box for storage and wireless charging, delivering extreme simplicity and convenience.
● Ergonomical Design
The ergonomically crafted in-ear earphones fit perfectly in your ears and won't fall out even during heavy exercise such as running and weight training. Various earphone sleeves and buds are provided so you can pick and choose based on what you need.
● Without Worrying About Sweat
POP has a waterproof rating of IPX5 and is resistant to sweat and rain.
● 5.8g Compact Structure
Each earphone weighs only 5.8g, which is lighter than a coin. The smooth, round body comfortably fixes in your ear for extended periods of time.
● One Touch Control
POP uses a touch control to operate, with a touch you can listen to music, make calls and access Voice Assistant.
● Stereo sound for a pure experience
Meizu POP offers crystal clear stereo sound, with audio data transmitted to both earphones. The sealed structure of the integrated microphone cavity and noise reduction technologies reduce background noise and echo, making the conversation effect as clear as face-to-face communication.
● Graphene Diaphragm for Balanced Tri-frequency
Adopt a φ6.0mm Hi-Fi dynamic graphene diaphragm that provides extended low frequency, powerful sound and balanced tri-frequency. The front cavity employs an air-pressure balance design to minimize pressure in the ear canal for maximum comfort.
● Open-to-connect for Convenient Charging
The earphone box integrates storage and charging and supports smart on/off using magnetic induction. The earphones automatically start when you take them out of the box, and automatically switch off and start charging when you put them back in the box. A Bluetooth device can be automatically paired when the earphones start up, so you can listen to music straight away.
● Secure Fit
Each earphone is only 0.2oz, various earphone sleeves and buds are provided so you can pick and choose based on what you need.
● Wireless Charging for All-day Use
The earphone box features a USB Type-C charging interface that's compatible with all mainstream wireless chargers for easy charging. A pair of fully charged earphones can operate for 3 hours continuously, plus an extra 12-hour capacity provided by the earphone box, more than you need for all-day use.
With the Meizu POP on GearVita, you can enjoy the best wireless experience with the least amount of money: https://gearvita.com/meizu-pop-true-wireless-bluetooth-earphones.html
Hot sale products:
xiaomi mi band 3 global version
xiaomi mi mix 3 128gb smartphone
The Huawei CF33 selfie stick comes with the integrated LED light, positioned just under the smartphone holder, that will enable you to capture amazing photos and selfies even in a low light environment. This selfie stick remotely connects to your smartphone via Bluetooth connection, and it can securely hold all smartphones with screen size from 4.7 inch to 6 inch.
Product Features:
● With integrated LED multicolored light.
● Suitable for all smartphones with 4.7'' - 6" screen size.
● Built-in fill light design, take bright and beautiful selfies in low-light conditions with less noise and natural skin color.
● Three gear adjustable brightness for different scenarios.
● One press switch, long press for on-off switch and short press for brightness switch.
● Remotely connects to your smartphone via Bluetooth connection.
● Extends from 18.5 to 61cm, for both close-up and panoramic shots.
● Compatible with all Android 5.0+ and iOS 8.0+ devices.
● Stable and durable aluminum alloy anodizing telescopic rod.
● Li-ion battery with Type C charging port.
● It could be used for flashlight and table lamp.
Visit this Huawei CF33 selfie stick on GearVita, its simple, stylish, elegant design and thoughtful functions will definitely attract you. With the extreme compact body, it is perfect palm and bag friendly for easy portability: https://gearvita.com/huawei-cf33-moonlight-selfie-stick.html
You may like:
buy xiaomi poco f1 lte 128gb
buy xiaomi lyej05lm
