Xiaomi Youpin SOOCAS X3 Sonic Electric Smart Toothbrush - Clean Better for Healthier Teeth
Feedback: +0 / =0 / -0
Xiaomi SOOCAS X3 sonic electric toothbrush is a rechargeable toothbrush that has 4 cleaning modes and a 1000mAh battery capable of providing up to 25 days of use. In addition, it is completely waterproof with IPX7 rated, and like any good Xiaomi products, can be linked to your smartphone. Simply download the Soocas application, which is available for both iOS and Android, you can configure the intensity, cleaning mode or brushing time of the Xiaomi Soocare X3. Also, it allows you to check the effectiveness of the cleaning or if the time has come to replace the head.
Product Features:
● High-frequency 37200 strokes/min sonic movement, helps to clean your teeth efficiently.
● Brush head is polished to be semi-circular, rounded bristle top is more safe and gentle.
● High-density DuPont bristle, soft and 40 percent increase in bristle planting, ensures a full-ranged gum cleaning.
● Built-in 2 minutes timer, with intervals every 30 seconds to let you know when to switch areas of the mouth.
● Intelligent APP control, synch your brushing time and habit, record in the APP, professional customized solution, multi-effect tooth care.
● 4 optional cleaning modes: clean/sensitive/gum care/polish, professional and scientific, meeting your different needs.
● Super IPX7 waterproof, full body washable, convenient to use and clean.
● Long lasting battery, USB fast charging, can use up to 25 days after fully charge.
● One button switch, simple and easy to operate.
● Connect the electric brush with your phone by Bluetooth, the APP will show you some information, such as the cleaning degree, the residual electricity, the time for replacing brush head.
SOOCAS X3 drives fluids deep into the tight spaces between your teeth and along your gum line, removes 700% more plaque along the gum line than a regular manual toothbrush. Taking care of your oral health is easy with a SOOCAS X3, it can effectively remove bacterial plaque and reduce gingiva necrosis, very practical and convenient: https://gearvita.com/xiaomi-youpin-soocas-x3-sonic-electric-smart-toothbrush-global-version.html
Other cost-effective Xiaomi products:
xiaomi 70mai pro gps
xiaomi qi standard wireless fast charger 10w
Designed for office operation and industrial application, the Minix NEO Z83-4 Mini PC is a compact system that fits in the palm of your hand and contains no moving parts. The system packs the performance of a 1.44GHz Intel X5-Z8350 Quad-Core processor with integrated Intel HD Graphics, features 4GB of DDR3L RAM, and 32GB of eMMC 5.0 Internal storage. The installed Windows 10 Pro (64-bit) operating system gives you a great surfing experience, HDMI and mini DisplayPort are able to deliver high-definition content to your monitor or TV at resolutions of up to 4K/2K UHD@30 fps. Using Bluetooth 4.2, you can wirelessly pair the NEO Z83-4 with external peripherals.
This Mini PC connects to the Internet for downloading content using built-in dual-band 802.11ac WiFi or the Gigabit Ethernet jack. For connecting with peripherals, it offers one USB 3.0 Type-A port and three USB 2.0 Type-A ports. The system operates quietly with minimal noise, and is also able to maintain a low operating temperature while also remaining energy efficient. Using the included 12VDC/3A power adapter, you'll be able to get started right out of the box with the power to play, create, and entertain.
Product Features:
● Intel X5-Z8350 Quad-core CPU is rapid and stable which can give you high-speed feedback.
● Comes with 4GB DDR3L RAM and 32G eMMC flash, can store a very large amount of data.
● Windows 10 Pro pre-installed, set up is effortless, ready to run straight out of the box.
● HDMI and Mini DisplayPort outputs available, multi-display ready (support up to two displays) that makes navigation between applications easier and improves productivity.
● The fanless passive cooling design maximizes heat dissipation, meaning all operations can be conducted in absolute silence.
● Supports dual band WiFi of 2.4G and 5G as well as Bluetooth 4.2 connectivity.
● With USB 3.0 super speed connectivity, data transfer speed could reach up to 5Gbps, 10 times faster than USB 2.0.
● 4K H.265 provides cool home theater experience.
● Bluetooth 4.2 provides fast connection to other devices, such as the mouse, keyboard, speakers.
● Supplied with the custom VESA mount for easy mounting on the back of the monitor or TV set.
The NEO Z83-4 Pro is a true thin client solution with the combination of its amazingly fast startup, seamless web browsing, multi-tasking, and compatibility with a wide range of productive offices software. In addition, the NEO Z83-4 Pro gives your living room an exquisite visual movie experience, making it the perfect home theater PC: https://gearvita.com/minix-neo-z83-4-pro-mini-pc.html
You may also like:
mi mix 2s global
xiaomi mi mouse
This Xiaomi Youpin Flydigi Stinger game trigger has the ability to either send a single touch response or multitouch response to the game (turbo fire/rapid fire). In a game like using guns, its definitely useful when you are using a AK47 with rapid fire than using it on single touch to take your enemy down. You can switch the button response to single or multi at the back and the multitouch will respond up to 8x, meaning it can fire 8 times in a single touch. But in a game of basketball like the NBA 2k19, you wont want to do the rappid fire as you can only release the ball once you get off the ground.
Product Features:
● Adopts the unique capacitance spacer mapping technology, which can achieve instantaneous response without failure.
● One-key switch between normal mode and continuous click mode.
● In the continuous click mode, long press the trigger button can achieve high-frequency continuous click, 8 times per second.
● Unique tensile structure for stable and convenient grip, with a better feel.
● Short key range of mouse-level microswitch, highly sensitive and responsive.
● A physical connection, common to iOS and Android systems.
● Using a stable stretch structure, lined with rubber anti-skid pad, clamped tightly with the mobile phone.
● The inside slot is designed to reserve space for volume keys and lock screen keys to avoid accidental touch.
● Maximum thickness support is 9mm, maximum stretch support is 82mm.
● Use time 80 hours with a full charging time of 1.5 hours.
Flydigi Stinger is designed for a more user-friendly experience, you don't have to take off your phone case when using it. Also, connection and control sensitivity will not be affected by screen protectors either: https://gearvita.com/xiaomi-youpin-flydigi-stinger-game-trigger.html
Other good products worth buying:
xiaomi mi portable mouse
xiaomi redmi 6 pro 64gb
Lenovo Lemei RHB01 smart wristband is equipped with 0.96 inch colorful display, and every function you want. Sleep monitoring lets you know your sleep status and adjust your sleep. The wristband will record full track of your exercise time, heart rate, step, distance and calorie, so that your movement is more scientific. Based on the pulse conduction rate technique, just wear the wristband, the blood pressure value will be detected by the optical sensor, and the APP forms the blood pressure report. It also monitor your blood oxygen content at any time, the higher the oxygen content, the better the metabolism.
RHB01 supports remote photo, you can switch to photo interface and long press or shake to take a picture. Sedentary reminder reminds you to get up and exercise after you sitting for a long time. Phone calls, receiving information or new messages from APP, automatically pushed to the handset via vibration hints. Turn over the wrist to wake up the screen, which is simple and cool, more convenient to use at night. IP67 dust-proof and waterproof grade meets daily demands of anti-dust particles, rain, sweat and wash water.
Main Specifications:
MCU: NRF51822 QFAC
Display: 0.96 inch TFT screen
Strap Material: Silica gel
Bluetooth Version: 5.0
Battery: 90mAh
Standby: 4-7 days
Charging: 3PIN charging clamp
Waterproof: IP67
System Requirements: Android 4.4 above and iOS 9.0 above
Main Functions: blood pressure, sports heart rate, blood oxygen, sleep monitor, sedentary reminder, step, distance, calorie, call/message/APP reminder, remote photo, music control
Coming with black and gold for option, Lenovo Lemei RHB01 also provides multiple dials to meets the needs of your personality: https://gearvita.com/lenovo-lemei-rhb01-smart-wristband.html
Related products:
huawei honor magic smart watch
xiaomi amazfit stratos 2
