"Camillia is a different species."
Seems so.
As far as camelina oil goes, it appears pretty similar to the related canola oil.
http://www.canola-council.org/pubs/fatcharts english.htm
Canola actually has more of the the anti-oxidant tocopherols (vit E).
Ten milliliters (2 teaspoons) of refined canola oil contain 1.9 mg vitamin E (alpha-tocopherol), providing about one-fifth of a man's daily vitamin E requirement.
http://www.canola-council.org/pubs/vitamine.html
That works out to 19 mg/100ml for canola, vs the 7.9 mg/100ml cited in the camelina link.
http://www.camelina.fi/oil.htm
This will likely come up, so--
Canola oil is NOT rapeseed oil--the plant has been extensively altered through breeding to produce a different product.
Edible vegetable oils are made up of components called fatty acids. These fatty acids determine the use of vegetable oils for either edible or industrial uses. Certain fatty acids, such as linoleic, are considered essential in human diets since they cannot be synthesized by the body but must be obtained from the diet. The rapeseed varieties that were grown produced oils containing large amounts of eicosenoic and erucic acids which are not considered essential for human growth.
As early as 1956 the nutritional aspects of rapeseed oil were questioned, especially concerning the high eicosenoic and erucic acid contents. In the early 1960's, Canadian plant breeders responded quickly with isolation of rapeseed plants with low eicosenoic and erucic acid content...
... an oil that must contain less than 2% erucic acid, and the solid component of the seed must contain less than 30 micromoles of any one or any mixture of 3-butenyl glucosinolate, 4-pentenyl glucosinolate, 2-hydroxy-3 butenyl glucosinolate, and 2-hydroxy-4-pentenyl glucosinolate per gram of air-dry, oil-free solid.
http://www.canola-council.org/pubs/origin.html
(Don't freak out over the glucosinolates either they're substances that are precursors to the compounds that give mustard a sharp taste. They were reduced so cattle would eat the seeds after the oil was pressed out--I guess they don't enjoy mustard.)
Bottom line, so far I see nothing to definiatively recommend the camelina oil over canola oil.
Would either be particularly suited for blade care? The very fact that they are particularly rich in unsaturated oils, which are the kind that oxidize polymerize would seem to suggest no. The polyunsaturated components will be the most reactive and produce the most crosslinking and polymerization. The endogenous antioxidants might prevent thickening and polymerization for a while, but they will eventually be exhausted since they provide protection by getting selectively oxidized themselves. The propensity of olive oil to get sticky and gummy on blades has been noted several times in the forum. Like camelina and canola oil, olive oil is mostly unsaturated and usually contains considerable quantities of tocopherols:
Olive oil contains a-tocopherol, the tocopherol with the highest vitamin E activity, in quantities varying from 1.2 to 43 mg/100g (1-3). On average, the amount present in the oil is about 12 to 25 mg 100g, as reported by one group (3). Others found even higher values of 24 to 43 mg/100g (2).
http://europa.eu.int/comm/agriculture/prom/olive medinfo/uk_ie/factsheets/fact9.htm
So far, I think that camelina, canola, and olive oil will likely behave similarly if used on blades.
OK, what about camellia oil?
Wow, this is a nice table:
"Camellia oil is pressed from the seeds of a certain plant in the camellia family. It contains rich nutrition with light color and pure taster. It is one of the richest that contains single unsaturated fatty acid in all of the vegetable oil; its unsaturated fatty acid is up to 85%. It is used in the field of cooking and cosmetics at present.
Items......... Monounsat. Fat...... Polyunsat Fat ....Saturated Fat
Camellia Oil ... 80% ..................8% .............12%
Olive Oil .......77%....................9% .............14%
Canola Oil ......62%...................32% .............6%
Peanut Oil . ....49%...................33% ............18%
**Camelina oil..ca32%...............ca56% .......ca 10% **
Corn Oil ........25%....................62% ...........13%
Soybean Oil.....24%.................... 61% ...........15%
Sunflower Oil...20%................... 69% ...........11%
Safflower Oil...13%....................77% ............10% "
http://www.bulkoil.com/scripts/bulk_item.asp?p_com 150
**Camelina values interpolated from the table appearing here:
and inserted into table.
Now, what to think? Looks like camellia oil and olive oil are the best bets, and one can expect canola oil to get thick and tacky, and camelina oil to be worse still.
I didn't find the amount of tocopherols in Camellia oil. It very much resembles olive oil in the fat profile. Both are very low in polyunsaturated fats. I suspect that it was the best product available many years ago, before other oils were available. I also suspect that it would eventually harden and get tacky as does olive oil. Considering the high level of care devoted to the impliments it is traditionally used on, I think that a build up of old oil was not allowed to occur. If anybody tries the camellia oil over time, a report would be appreciated.
It should be expected that the oils with the most polyunsaturated fat will be most prone to thicken or harden through polymerization, as described in one of ddeans interesting links:
What characterizes a drying oil? The ratio of the rate of oxidation of Oleic, Linoleic, and Linolenic Acids is 1:10:25. It is easier to polymerize carbon chains with two nearby C=C bonds (linoleic) than it is with just one double bond (oleic). Three such bonds in close proximity make it even better (linolenic). The presence of the three double bonds also promotes the 3-dimensional gel cross-linking, as does high GU3 content.
http://www.members.iinet.net.au/~nickl/wood.html
Note that from the table in
the amount of oleic: linoleic:linolenic acids is
10.24:14.75:38.72 or about 1:1.5:3.8.
probably eicosenoic acid (abundant homolog of oleic acid) should be counted too, which would give something like:
2.5:1.5:3.8
(Recall that eicosenoic acid isone of the components that was deliberately bred OUT of canola--it's present at nearly 11% in camelina!)
For tung oil, from
we get:
2.3:1.6:5.2
....considering that the non-drying(coconut, olive, peanut) and semi-drying oils(almond, corn) don't have any linolenic (or in the case of linseed oil eleosteric) acids with three double bonds, and camelina oil has a lot of linolenic acid (38% as the alpha form) one might even expect camelina oil to be drying oil! I'm not going to bother to see what another drying oil, walnut oil is like, though--I've had enough.
Is this horse dead yet??
