- Dec 7, 2019
Relative to the big three of steel, heat treat, and geometry, how important is rockwell hardness? What would be your ideal hardness values for different knife roles? (chopper, kitchen work, edc, hunter, etc.)
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Mine goes up to 11
But the real question is girth vs. length. Of course, both is where you wanna be, but if you can only have one...Every woman is different. Some like it harder than others...
Yeah, good thing Cedric and Ada exposed that. Lots of non-knife folk probably fell for that.Ideally (big stress on this word) we need a steel or equivalent material that is 10 on the mohs scale (so way above 70 HRC), 100+ ft/lb in toughhess on standard v-notch charpy test, and corrosion resistance on par with commercially pure titanium.
That steel or equivalent material would be ideal for any situations, be it chopper (thicker stock) or kitchen (thinner stock), and every type of knife in between.
In all seriousness, that's an odd way to frame the question because hardness is extremely important for having a knife to even hold an edge for any real use. I'm not sure where the cutoff point is, but I'd say that 55 would be the bare minimum a knife needs to be do have structural integrity for an edge (yea, I know, throwing knives are hardened much softer, but they're not used primarily for cutting stuff).
You can't use pot metal to make a knife. Well, you can, it just won't be a very good knife and will be difficult to sharpen and it won't hold an edge long enough to do real work.
With modern tech, the hardness/toughness debate is kinda moot. We have highly alloyed 60+ HRC-possible steels that have higher toughness than low alloyed 55-57 HRC steels. Some of the steel/geometry used in those BladeSports chopper knives could be easily adapted to kitchen duty.
