his disassembly vids help a lot of folks out there.
Your recent opinion on Nick Shabazz ?
He's great (you're great).
Hey Nick from watching your take aparts I got the confidence to go for it.
Then . . . what's this ! ! ! ! . . . no take apart for the Delica
You took it down.
Put up a don't do it vid.
But I needed to switch the blade from one Delica to another. I want the HAP-40 in my black FRN.
'bagger gotahaveit !
. . . oh now them guys (and gals) at the factory do it.
I watched some other guy's vids . . . they scared me . . . not the fact that it was "the difficult Delica" . . . the "don't do it Delica" . . . it was more along the lines of them calling the TORX screws ALLEN screws that really freaked me out. Use tools much ? ? ?
Not confidence building to say the least.
Nick YOUR vids are confidence building.
So . . .
its you an me dude.
I just rebuilt two with great success thanks to your heads up about the vulnerability of the slot in the plastic (that's not FRN to ?). In any case I agree it looks vulnerable.
The little lock bar spring flew clear across the room only once. No . . . I meant to do that . . . I was going for hight AND distance
. Nah I got my "system" down now. I got my method I had to get "in the groove" hun ? hun ? . . . (I bet I could flip one clear across the street now).
No but seriously; all fooling around aside (for now).
I got the solution to that vulnerability in the rebuild process and Nick . . . I think you should give it another go. Obviously I don't have what it takes to do a real video like you can. No really; you got it down and we would much rather watch one of your vids than mine. Trust me on that.
Without further ado; to support the little plastic back spacer at the slot :
- Some tape the blade to keep from getting cut. I used a short piece of kitchen knife blade guard (one inch width). Heck you might want to tape that to the blade to keep it from slipping off.
- put the spring in the slot (no lock bar yet leave that off).
- With the blade in place over the pivot with the bronze washer on top of the blade, place the steel liner down on top of that.
- Put the scale on the stack up and put the three rear most screws in the handle and the screw in the blade pivot. Leave them less than tight. With the handle fully but loosely assembled the lock spring cannot take flight. AND the spring slot is now fully supported by the steel liners on both sides of it.
- With the lock bar pivot pin removed and the blade in the open (deployed) position put the lock bar into the handle and then press down at the thumb groove while keeping the blade all the way open so the lock bar can fully seat in the blade notch.
- Push the lock bar pivot into place (being mindful of the flat side engaging with the flat in the liners) until the pivot slips through the lock bar enough to hold it in place.
- Put the side of the knife down on the work bench and pressing the lock bar all the way push the side of the knife down on the table until the lock bar pivot is fully seated.
- Release your finger pressure on the lock bar and put the final screw into the lock bar pivot.
You are all back together dude !
Do you see how
the two liners being in place with the little tits on the plastic spring support / back spacer engage with the liners to support the vulnerable slot in the plastic (FRN ?) ?
Once that is fully supported only THEN do we put force on the spring and slot by putting in the lock bar.
Viola !
I'm not a vid maker but I'm a mechanic.
The old crotchety dude in the back grumbling
to himself . . . yeh that's me.
Go again Nick
I just wanted to contribute where I can.
We're all in this together.
