I won't agree that ZDP 189 is more brittle than any steel with a lower RC. 440C at 61-62 RC hardness (or even VG-10 or S30V at 62 RC) would be lower RC and probably be way chippier than my 64.5 RC Stretch. I go with thin backbevels (generally 7-10 per side) then microbevel at 15-20 degrees per side and I haven't had any undue chipping (hit a packing staple with most any steel and you can expect a little chip when using a decent edge geometry that isn't axe thick). Sure, VG-10 at 59 RC may roll where 64.5 RC ZDP may chip, but either way you have to do a full resharpening to remove the chip or the weakened steel from edge rolling. I personally love CPM M4 because at 62.5 RC it hasn't chipped with a 10 degree per side edge even when cutting directly on the bones of a 400 lb. Hog to remove his lower legs and head. ZDP, S30V, and VG-10 all would have chipped there, but then again they have much more corrosion resistance. Either way yes, ZDP can chip more than most other common high end steels like S30V and VG-10, but VG-10 or S30V would probably roll or get a flat spot instead of get a small chip like ZDP on a tough cut. Also, if you are complaining of ZDP chipping without doing a full resharpening then you may not be getting a true look at what ZDP 189 is capable off. It isn't uncommon for factory edges in any steel to be chipping from possible overheating of the edge or a left over burr from the factory sharpening. If your ZDP knife continues to chip after a full resharpening to a reasonable geometry then send it in to the factory to see if they can find anything wrong with it. I have found for normal EDC cutting like packing straps, cardboard, rope, plastic blister packs, ect. ZDP performs great with no chipping. If you cut metals or other nasty stuff it probably isn't the best steel for you.
Mike
