- May 19, 2018
So, I thought I'd get a discussion going on Zirconia belts and people's experiences with them.
I bought a ton of them on supergrit.com to try out. The grits they carry don't go higher than 180 grit. So I've mainly been using them in the coarser grits 100 and below.
I'll lay out my observations below and I hope others will chime in! I'm especially interested in if seasoned makers humor the use of zirconia belts at all! I haven't caught much wind of their use besides a video where Walter Sorrels mentioned he uses them on occasion.
Longevity - they definitely seem to last alot longer than aluminum oxide belts. I was able to use a worn 60grit belt for fine tuning profiles and the like until the tape joint failed (and it was still cutting!)
Cut rate - they are advertised as faster cutting than aluminum oxide. This may be the case but in the real world I could not tell a substantial difference between an equivalent grit aluminum oxide belt. Maybe slightly faster cutting. Does this measure up with anybody else's experience?
Heat build up - I actually find the zirconia belts to build up heat MUCH faster than an equivalent aluminum oxide belt. Am I doing something wrong?!
Scratch pattern - I have found the scratch pattern to be a tad more consistent/even than an aluminum oxide counterpart.
Is it worth the ~$1-$2 savings per belt to a standard ceramic belt? I'm not so sure.
I'm really curious to hear about what others think of them. Is there a specific use zirconia plays in anybody's shop? Is there an instance where anybody prefers them to ceramic, silicon carbide, or aluminum oxide? Humor my curiosity!
