bodog
BANNED
- Dec 15, 2013
Well guys, since ZT claims they make knives for professionals and first responders and that their knives are built like tanks, I decided to give the 0180 a good test to see if what they say holds true. I decided on a fixed blade because their folding knives have had a lot of controversy surrounding their lock interfaces. A lot are great and some not so much.
I didn't get pictures of the first round because it was a test primarily for myself at first, then I decided to go ahead and give it a full run and document it so others could see too.
The first round consisted of me giving the knife a sharpening job up to 14,000 grit where I had a clean mirror polish and the knife could whittle hairs, cut clean S curves into paper with a push cut and cleanly draw cut toilet paper. I took the knife out into the woods and found some suitable branches. I started by simple whittling for a while to get a true sense of the ergos and if the blade/steel could withstand even simple use without losing an edge. It did easily. Shaved hair with ease at that point.
I then found a small tree about 10 inches in diameter. I know this knife isn't really a chopper but I really needed to see how well it did hacking on wood for awhile. After spending about 30 minutes hacking on this small tree, I felled it. My hand was a little sore but not terrible and not unexpected given that this knife obviously wasn't designed for such work. The knife still easily shaved arm hair.
I then took it to my garage where I have a lot of boxes from a move I made about a year ago. I made somewhere between 100 to 200 (edited, way overshot that estimate) cuts on primarily double walled cardboard and some single walled cardboard. After that the knife still shaved arm hair with relative ease. I decided that the knife was tough enough and went back out into the woods for what I thought would really dull the knife. I found a good size branch that hadn't rotted yet and started making exaggerated and pretty stupid twisting hacks/cuts into the branch for about 5 minutes. My hand at this point felt kind of mangled so I called it quits for the day. I tested the knife a last time and it still kind of easily shaved arm hair. It wasn't the easiest thing in the world but the right angle had the hairs still falling off. At this point there was no real discernable edge rolling or chipping, just the minor dulling. The knife passed my tests but now I was curious how far I could take it.
I rested the rest of the day and the next and then went to an old garage I knew has been abandoned for a couple of years. There's plenty of stuff to cut up and smash, so that's what I did. The pictures should tell the story from here on.
Old thick rubber boots, this was a little difficult
Old leather boot. Cut in half easily.
I stabbed the glass and it shattered with ease. Hitting it with the butt did nothing
PVC pipe was stupid easy to cut/break
