Hickory n steel
- Feb 11, 2016
What leatherman model is it ?I believe I'll take a hard pass.
The way the tools/blades are set up to be on the outside when the handles are open, they'll dig into the hand when using the pliers.
Thanks, but no thanks. I have an unused for that reason multi tool already. I don't need two ...
I can assure you this is absolutely not the case.
I just used my trusty fuse yesterday at work to cut some 1/8" diameter steel rod, and I did not feel the tools one bit.
The edges of the " frame " ( the nylon inserts actually) yes I felt them but not the tools.
The well folded over edges of the frame here should be even more comfortable in use.
Don't let that potential concern keep you from trying this tool if you're otherwise interested.
