- Apr 26, 2024
New knife-maker here so go easy on me,
I was given a Butcher Knife with a spine thickness of about 3.2mm. The idea would be to reduce the thickness of the blade down to about 2mm and turn the Butcher Knife into a Vegetable cutting knife. I have a Grizzly 2x42 Knife-Making Belt Grinder, as well as low grit (36, 60, 80) Ceramic belts for it. I tried grinding down the thickness using the belt grinder and 36 grit for about 30 minutes to no avail. I believe it's stainless steel.
Any ideas on how I could reduce the thickness of the stainless steel? Would I have to normalize or anneal the steel first? Than re-heat treat it after grinding it down?
Thanks!
Thanks!
