- May 9, 2000
Ouch! I've cracked a blade! Can anyone explain what went wrong (guesses)?
I forged a simple blade out of 1095 bar stock, 1/8 thick x 1-1/4 wide. Not much forging, but a first try. It took many heats as I only had a 12 ounce claw hammer at the time. I forging heat was from 1500 F to light glow. I packed the blade at the light glow range then annealed. I roughed the grind then heat treated. I quenched in 70 F olive oil and tried to differentially quench (the edge half of the blade in the quenchant). After cleaning up the blade prior to tempering I noticed a crack starting at the edge and going 3/8 inch toward the spine (half way down the blade).
Can too many heats cause this? Any guesses as to a possible culprit?
Thanks,
Dan
Thanks,
Dan
