shunsui
- Aug 12, 2008
Here's a couple of other tips.
Here's a little info on the Loctite Threadlocker Blue 242 (removable) from the data sheet.
"In rare instances where hand tools do not work because of excessive engagement length, apply localized heat to nut or bolt to approximately 482°F (250°C). Disassemble while hot."
If you do end up with a stripped screw, you can try drilling it out with a reverse or left handed drill bit. Use a small size and drill through the center of the stripped screw (carefully). A drill press is a good idea.
