- Feb 22, 1999
We have introduced several exciting new products for 2001 and I'll be the first to admit an update to our website is long overdue. We are now in the process of adding these new items to our site. The following lists all our new items for 2001 with complete product descriptions. As always we thank you for your support and look forward to your comments.
David Bloch
3" Impulse - A scaled down pocket-carry version of D. Ralph's original Krait design with Kraton innerframes, raised bolsters for increased pivot strength, recessed clip and plenty of style. The 3" Impulse is available with grey bead blast finish and black Teflon coating with plain or serrated cutting edge. This has been my daily carry knife since it was first introduced in September. $54.99 Bead-blast and $59.99 Black Teflon MSRP
3" Paragee - Edge-Techs new Paragee designed by custom knifemaker Darrel Ralph is a stylized, hard working folder with solid stainless steel frame-lock construction. Unlike traditional locking liner knives, the Paragee split handle frame locks behind the blade for unparalleled strength and lock security. The 3 recurve blade design is Darrel Ralphs trademark and cuts more powerfully than a straight edge blade. The planetary innerframe handle minimizes weight and greatly enhances gripping. The Paragee features ambidextrous thumb studs, pocket clip and a Sub-0 quenched AUS-8A blade. If you are looking for a light, strong, folder with a reliable lock thats loaded with style, the Paragee has it all.
Blade: 3, 6.5 Overall
Weight: 3.5 ounces
Blade Steel: Hitachi AUS-8A Stainless
$54.99 MSRP, Release date is March of 2001
NEW! G-Force
The G-Force is a revolutionary new multi-carry fixed blade system. The stylized reverse curve blade is extremely light weight and balanced to cut powerfully under the most extreme conditions. Three geometric blade slots minimize weight and improve overall balance. The handle incorporates three sets of concentric Pivot-Rings for easy rotation from a forward to reverse grip. The versatile quick-release sheath system includes a unique spring clip/belt loop attachment and neck chain and for a multitude of carry options. This attachment functions as a spring-clip for quick release or can be fastened as fixed belt loop. Deployment options include but are not limited to vertical belt carry, inverted inner pocket clip carry, horizontal and neck carry.
Blade: 3", 6.5 Overall
Weight: 3.5 ounces
Blade Steel: Hitachi AUS-6A Stainless
$24.99 MSRP, Release date is May of 2001.
Pack Axe - Our new Pack-Axe is the ultimate hand axe for splitting firewood, quartering big-game or setting up camp. The Pack-Axe features one piece full-tang construction and is hot drop-forged from a solid molten bar of 1050 tool steel for ultimate strength and durability. The Pack-Axes extra wide splitting head is perfectly balanced and features a rubberized Kraton handle for non-slip grip and control. The Pack-Axe comes complete with a nylon belt sheath and lifetime guarantee. Overal Length: 10-7/8 Weight: 19.5 ounces. $39.99 MSRP
Pack-Saw - Our new 3-Blade Pack-Saw is the most versatile and compact take-down saw available. The Pack-Saw sets up from its stowed position to a sturdy 12 bow-saw in seconds. This set includes three blades for wood, bone and metal and comes complete with a nylon storage case for easy packing. Blade Length: 12, Weight: 14 ounces. MSRP is $24.99
Sportsman's Multi-Tool - The Sportmans Multi-Tool is a must-have item for every bowhunter, rifle hunter and muzzleloader. This versatile multi-tool features a heavy duty plier head with nock point crimping tool, wire cutter, clip-point knife blade, gut hook blade, wood-bone saw, 3-4 blade broadhead wrench, chisel, can-bottle opener, needle hole punch, lanyard attachment, 9 ruler with inches-centimeters and a magnetic ¼ drive bit adapter with twelve assorted flathead phillips head and hex bits. The Sportsmans Multi-Tool and all twelve bits store in a compact nylon belt sheath.
Overall Length (Open): 7.0 (17.8cm)
Overall Length (Closed): 4.5 (11.4cm)
Weight: 11.5 ounces $19.80 MSRP.
TREK-TOOL
The Trek-Tool is a complete tool box which carries on your belt. This versatile multi-tool features a spring loaded heavy duty fine/course plier head with wire cutter, ½ plain-serrated edge knife blade, double sided file, saw, chisel/scraper, can-bottle opener, needle hole punch, lanyard attachment, and a magnetic ¼ drive bit adapter with twelve assorted flathead , phillips head, hex and Torx style bits. The Trek-Tool and all twelve bits store on a compact nylon belt sheath. The Trek-Took features Swirl-Brush handles and contoured no-pinch style grips.
Weight: 12.0 ounces
$21.60 MSRP
David Bloch
Weight: 3.5 ounces
NEW! G-Force
Weight: 3.5 ounces
TREK-TOOL
Weight: 12.0 ounces
$21.60 MSRP
