After following the directions I have a full knife. For a larger knife it might work better but smaller knives such as a case Texas jack or even small rapala filet never get sharp. I get better results using a ceramic rod but that is not always the answercan you provide a bit more detail? What results are you getting currently? Personally, i've found this device to be one of the most simple powered sharpeners to use and get sharp blades fast with the one caveat that unless you follow their instructions to the T, you may experience excess metal removal.
not sure I follow...are you getting good results with large blades but NOT small blades? Like nearly every other sharpening system, aim to develop a burr (wire edge) from sharpening one side only. once you feel the burr, proceed to the other side to deburr.After following the directions I have a full knife. For a larger knife it might work better but smaller knives such as a case Texas jack or even small rapala filet never get sharp. I get better results using a ceramic rod but that is not always the answer
Large blades are ok. Small blades not so muchnot sure I follow...are you getting good results with large blades but NOT small blades? Like nearly every other sharpening system, aim to develop a burr (wire edge) from sharpening one side only. once you feel the burr, proceed to the other side to deburr.
