- Jun 25, 2018
Anyone able to post a few side-by-side photos of Vildmark/Apache/Lil Ferox?
Perfect! TY
I recently had the opportunity to check out a beautiful Vildmark from the last group buy courtesy of my great friend @Kal-El . I went back and forth whether or not to sign-up for the group buy because I was unsure how much the Vildmark varied from a nice “K” Apache I already have. If you are in the same boat trying to decide which model is right for 000 in the new custom order thread opening tomorrow, I hope the following photos help you make a good decision. Please keep in mind that each of these knives is hand made, so some slight variation is inevitable from knife to knife.
The blade and cutting edge lengths are very similar on both models. The Vildmark is guard-less which I like on a bushcraft knife. The “K” Apache has a taller blade and grind which is thinner behind the edge and yields more finger clearance for food prep if that is important to you.
The shape and length of the bottom handle contours are very similar on the two models. The Vildmark is slightly longer (1/8” or so) in this area even though it doesn’t show well in this photo.
The top handle length is approximately 1/4” longer on the Vildmark than the “K” Apache. The Vildmark has nicely rounded corners on the pommel that I much prefer over the sharper corners on the “K” Apache.
These two knives differ most on purpose specific handle thickness and contour shaping. The Vildmark has a much thicker handle in the palm swell area and pommel end, with inward tapered flats on the front end. The “K” Apache has a thinner handle profile in the palm swell and pommel end, with an outwardly flared shape on the front end.
Focusing solely on the Vildmark, I found the handle profile, length, thickness, and contouring a super comfortable fit for my average size hand (i.e. large glove size.) There is enough extra room on the bottom of the handle to accommodate larger hands than mine.
I appreciate the inward tapered flats on the front of the handle that make transition to a forward pinch grip very natural on the Vildmark.
A couple of comments relative to this specific Vildmark:
I could stare all day at Chris’s hammer-textured flats. That is one of his signature features that has reached a high level of consistency and perfection over the years he has been developing it.
The wood on this knife is blue-dyed Buckeye Burl. Even though I am mostly a synthetic handle guy myself these days, I admire the color, figure, and beauty of premium handle materials like this.
Conclusions:
If I was looking for a knife primarily geared toward bushcraft activities, I would select the Vildmark for its thicker handle contour and forward tapered flats that allow better leverage and control of different kinds of detailed cuts and reasonable sized batoning. If your uses and outdoor activities are primarily focused around food prep and/or game prep with secondary uses in wood carving and/or batoning kindling material, then the “K” Apache might be a better choice.
I encourage you to dig deep and be realistic about your uses if you can only choose one. If you can afford both, by all means get both.
I want to close by again thanking my friend Sergio for lending me his Vildmark to make this comparison possible. I have learned much from you because you set the bar very high with everything you do.
Thanks!
Phil
Great write-up Comprehensivist - Phil you always set the bar high. The side-by-side comparison photos are always the most illuminating aspect of any review for me. I have always appreciated you for taking the time to plan, snap and share these photos over the years.
Having never held either of these models outside of the original Apache, I have concluded much the same from assumptions made staring at the knife pics posted for each model. I never realized how chunky the Vildmark's handle was until now, and I see why it would be a standard feature as opposed to a more kitchen oriented knife where I like to have a little more finesse.
Regarding the forward thumb scalloping on the Vildmark handle: how would you feel if this was reversed on the two knives in question and the K-Apache had the scalloping while the Vildmark had the corner? Going back to "finesse," that forward handle scalloping does offer a subtle increase in comfort. In a kitchen/food prep setting, where I use a pinch grip most often, a knife sized like the K-Apache you would be pinching right at the forward handle, just touching up on the blade as you demonstrated in your photos. It seems like it would be a slight functional upgrade here in feel. The Vildmark I can see having it either way. With a gloved hand you won't notice for the most part, but I do feel that those corners give you more traction especially when working with gloves.
I agree with you, there is nothing quite like that "feathered" texturing. I have some of the older hammered flat styles, but I do think he is on to something with the currently used texturing.
