Ok guys, we are past the half of Q1, time to put workpants on and make some bowies.
This week so far I managed to fit a guard blank. It's stainless, it was a pain to machine.
I mill the slot with heavy reliance on DRO.
Here you can see how I proceed - after drilling out most of the material, I make a pass with a given offset from the centerline (left column) and then I note the resulting slot width (right column - measured with gage blocks).
This way I can get a feel for how much material I will remove in a pass, including tool deflection and all that.
I was aiming at 6.03 mm, ended up at 6.01 - so about 1 thou under. I thought I will be able to hammer it home, but nope - so I made some spring passes and in the end the fit is ok (I may tweak it more later).
Then it's time for the frame. I had this idea about doing the frame and a spacer behind the guard from a single piece of material. I do not advocate this approach, I think it's not an efficient use of material. But I had a chunk of scrap brass that was the perfect size so I went for it. This is the basic layout.
First I wanted to mill the "mouth" of the slot into which the tang will fit. But to do that I thought I will first make a space behind this "mouth" so that chips can evacuate easily.
Then stand the blank up, and do the usual dance of milling a slot - predrill to remove the bulk of the material, then make a milling pass around the centerline, check width, repeat.
After that I laid the blank back down, and milled away one side. The blank is then flipped, referencing the front using a stop block you can see at the left side of the milling vise. That way I can mill to the same number in the X axis and I know both sides will be milled to the same point. For depth I also use DRO - that is the MVP of all this.
And here we are after all the milling
Now to remove the inside - I used 10 mm drill to get rid of most of the material.
And then file, check fit, file, check fit, rinse and repeat.
Getting closer
Almost there - removing material where it's in the way (as best as I can tell)
Once a good fit was achieved I roughly ground the outside to match the handle profile.
It's starting to look like something.
Now I am thinking the guard may be too thick, and I may shave a milimeter or two in thickness. But let me know what you think.
