- Feb 16, 2009
Thanks,
Yes, it's this maker.
TY
TY
To my knowledge the earliest SOG Seal 2000s (including this first 100 run)came with the nylon sheath, then the first kydex, then the second kydex that had a line cutter cutout. The sheath in your photo is not a SOG sheath. I have never seen that sheath before, but it is intriguing as it uses ACW nylon locks and straps and they are a big military provider. Also the bottom strap clearly indicates that it has "dive knife" in mind.Has anyone here seen an early SOG SEAL 2000 knife (shown above) come new with this scabbard?
Thank you... cj
Looks like a Blackhawk! sheath, I have one for my KaBar. It will fit most 7" knives.Hi,
Yes, i have always this model.
Some days ago, i found an other that my Uncle bought.... quickly
Now, only 3 know...
Stay 97 to find.
Photos of his knife :
Would a Seal 2000 fit into the shape of that sheath? It almost looks like it;s designed for a straight dagger. Unless that vertical protrusion is above the actual blade holding portion.
I spent years buying and selling knives on Ebay and know that 99% of knife sellers on ebay don't know anything about what they are selling, and they will sometimes just "make things up" to get something sold. I do not believe that sheath came with any SOG Seal 2000. At least none that were made available to the public.Thanks for your help... A friend just purchased an early SEAL 2000 on eBay (334425997650), the seller told him that this style scabbard came with "some" of the first SEAL 2000 knives, I am trying to determine if this is true. None of the auction photos show the knife in the scabbard, I assume the knife will fit in the scabbard, when the knife arrives we will know for sure. The same seller sold
an early SEAL 2000 in March (334363278381), that knife came with what I believe to be a correct nylon scabbard.
These sheaths were for the commercially sold Camillus Mk2 around the mid 90's to 06.Has anyone here seen an early SOG SEAL 2000 knife (shown above) come new with this scabbard?
Thank you... cj
Yes I have a Recon Bowie SOG. Could be the first run when they started selling Vietnam style Recon Bowie. On top of the pomel is marked 099. Also have a flash tanto Sog. Handle is shaped like a gun. It is a folder with assisted open. It was made back several years ago.on the other side says 440 steel. I can't find it. Thanks.I sent to the SOG cie, here retail@sogknives.com, 4 days ago, the same message... But, ANY reply. Maybe that this Cie is out, dead, or other....
I can't imagine that they don't have any information about this (rare) marking engraving model.
Here : http://www.m9m4.com/index.cfm?currentpage=68
My 2000 Recon Bowie SOG was the first run I think but was not a seal's knife. It was a anniversary model. Had it marked on blade.To my knowledge the earliest SOG Seal 2000s (including this first 100 run)came with the nylon sheath, then the first kydex, then the second kydex that had a line cutter cutout. The sheath in your photo is not a SOG sheath. I have never seen that sheath before, but it is intriguing as it uses ACW nylon locks and straps and they are a big military provider. Also the bottom strap clearly indicates that it has "dive knife" in mind.
Nice Mister Moon! I just picked up two stamped SEAL trident SOG 2000's from a collector in Japan with two different style sheaths. They're definitely hard to come by here in North America. I've been trying to find them for a long time and I finally had the opportunity.Hi guys,
Some years ago, i bought a SOG 2000, SEKI JAPAN, first generation blade markings but, after some search, i found only one photo on the web, maybe a "PRIVATE MUSEUM COLLECTION". Add. information are welcome!
SOG 2000 model with the EAGLE Seals, engraving.
I would like to know, if you have accurate information about this model?
How many made etc etc.
Thanks for an eventual reply.
Mister Moon
I concur, KenHash! When I was trying to scoop up a lot of Ontario Knife Company's USMC prototypes from the early 2000's USMC bayonet trials that led to the OKC3S the current crop of folks at the company were clueless and couldn't convey any background info from that time period ... lost development history, unfortunately! I envision a binder of engineer drawings and USMC bayonet trials data collecting dust on the top of a cabinet in the attic of OKC.That's the usual problem with trying to look up info on an old vintage model of any maker. Most of the front end people are too young to have any first hand knowledge.
In addition, there are "oddities" that can emanate from the OEM factory, that SOG head office doesn't have records or any information on. Usually, unless a particular model, in any configuration, was sold in the U.S., they won't have any info.
But hopefully in this case, I am wrong.
Mister Moon, I have two of these Trident stamped SOG SEAL 2000's and a gentleman in Taiwan on Facebook's 'International Bayonet Association,' Jame Chang, has posted photos of two as well. Regarding the two I have, one has a nylon sheath similar to yours and the other has a very robust four-slot Kydex/Plastic sheath similar to some retro KaBar/Camillus style plastic sheaths. Some of the characteristics are "USA" molded on the front; two wide leg straps that thread through the slots in the scabbard; a long hip/belt extension with a fastex style disconnect buckle. It's the second version with this style sheath I have seen so I doubt it's an accident, plus, many sheaths between SOG/KABAR/Camillus look to have been shared among these different vendors with their various lines of knives. Since very little is known about these early stamped Trident versions I think the robust scabbard was a transitional sheath before the final design was finalized. On the production version, there were several different sheath versions available with the Seki SOG 2000.Hi,
Now, only 3 know...
Stay 97 to find.
crayj ... Mr. Moon mentioned his uncle has a Trident SEAL stamped SOG 2000 with that exact same Kydex/Plastic scabbard in the photo you posted. I also have the one I got from our friend Gregg that has that same scabbard you posted. Now that I have looked into these early stamped versions I have seen them with four different scabbards (There are even more scabbard styles when compared to the unstamped production versions).Has anyone here seen an early SOG SEAL 2000 knife (shown above) come new with this scabbard?
Thank you... cj
