Since they are not sponsored by BladeForums I can't put a link here, but the description you can search there is
PH PandaHall Tibetan Antique Silver Spacer Beads
on the far right select that one, they have a 5mm diameter hole. To use them on my lanyards I will cut out the inner strands on one of the paracord legs just about an inch so it will be thinner at the end so I can get the two strands through the smaller hole.
G2
edited to add some visuals
Pull out the inner strands a little and cut them off, then pull the paracord so the hollow outer casing is...hollow
Untitled by
GaryWGraley, on Flickr
I'll trim the end at a 45 so it will be easier to slide it into the bead later on
Untitled by
Use a lighter to lightly singe the paracord end so it doesn't fray
Untitled by
Then slide the full thick side through first and then slide the thinner strand in, once you get it through, you can pull the full paracord through, it's just hard to get both in if they have their inner cores at the start, on very small bead holes I'll do the reduction on both strands and just muscle the thicker portions through afterward...hopefully, some beads have very small holes so it can be a struggle.
Untitled by
And the purpose of this small keeper bead is for an accent on my bobtail fobs
Untitled by
and on my regular lanyards the snake knots can start unraveling as snakes tend to do, so the bead keeps them under control
Untitled by
