Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
I saw there was an older thread, felt a new one was due. Just picked up one of these from
whitty
at USA Made Blades.
Simply a beautiful knife, designed by Jerry Fisk and produced by W White River
Untitled by GaryWGraley, on Flickr
The sheath provided is solid and well made but for myself I prefer a pouch style, so when I go to draw the knife, I don't have to fiddle with a strap or worry if I might cut it and on the return to the sheath, again watching that strap's position as well as finding that slot in the sheath isn't instinctive to me, but again for carry it does the job.
Since the guard is quite long, better to protect my hand, the pouch opening needed to be wide and open enough to receive the guard. So on the welt portion, three layers of leather, a bottom and top that are skived down to make a smooth transition and a center layer that runs the length of the sheath to protect the stitching from the blade, all layers are glued as well.
I put a belt loop on by using a copper rivet, this allows the sheath to swivel when you go to sit down and provides easy access to the knife handle. And the larger opening makes it simple to guide the tip into the sheath and then push down to seat the guard against a ledge of leather inside. The top welt area has a very slight curve so the guard rides down against that until it rests at the bottom.
Again, very nice knife!
Thanks to Jerry Fisk and to wrcb for coming up with such a blade.
G2
PS I do not take orders for fixed blades, I just make folding knife sheaths, but, when pressed to make something for myself, I will indulge once in a while
G2
