- Apr 18, 2022
New member, pretty much just been lurking and reading. I came across this research that I thought folks might find interesting, so thought I’d share it. One significant finding is that oiling a cutting board greatly reduces its antibacterial properties (can’t post link, so title below)
“Wood species, coating, and time all affect the ability of wooden cutting boards to move bacteria and ‘clean’ the cutting surface. All coated samples had significantly more bacteria on their surface than did uncoated samples. Unfinished European beech, generally, had the lowest recoverable amount of bacteria. The exception to this was when the wood was inoculated with Listeria, in which case uncoated oak (white and red) had less bacteria than the diffuse porous woods. Although a ‘better’ wood species was found, it did not perform uniformly across all tests, and wood generally considered undesirable for cutting boards (red oak) did perform well with Listeria. All boards had a decreased bacterial load over time, which was expected. Broadly speaking, all coatings interfered with the wood’s ability to move bacteria, causing increased surface bacterial loads.”
“These results run counter to popular understanding of wood cutting board maintenance and will hopefully impact the way households and professional kitchens use and care for their food-contact wood in the future.”
Wood Cutting Board Finishes and Their Effect on Bacterial Growth
