cudgee
- May 13, 2019
More info.This should be first on the list for those who can use it. Made a big difference with my Apex.
The EdgePro Apex affixes to a work surface with two section cups the rear legs. This works ok, but they can come loose and the front legs aren't secured so they can move up and down a little. The bench mount connects a piece of metal (aluminum if I recall - not near mine right now) toward the back of the EP that can be clamped down to a work bench. So it can only be used on a bench with open space under the surface. It can't be used on a typical counter top.More info.
Sorry i miss read your post, you meant the Edge Pro Apex, i thought you meant some attachment, sorry for the confusion. But i agree about the Edge Pro, i liked the design so much i have put together my own sharpener based on their model, and it does not need any base clamps, it sits solidly on any bench. But i also agree with you about all the add on features, they soon add up to make any sharpener an expensive unit. Most of the clamp systems have a heap of add on clamps and other accessories which make them very expensive. But one of the first things i did with mine was to make a magnetic base for an angle cube to sit on hands free, so i can adjust the angle properly. Thanks for your input.The EdgePro Apex affixes to a work surface with two section cups the rear legs. This works ok, but they can come loose and the front legs aren't secured so they can move up and down a little. The bench mount connects a piece of metal (aluminum if I recall - not near mine right now) toward the back of the EP that can be clamped down to a work bench. So it can only be used on a bench with open space under the surface. It can't be used on a typical counter top.
You then use a clamp to connect the bench mount to your work bench. The result is that the EP feels more secure and stable.
I get that all these little items add up. By the time you add all the accessories it's no longer a lower priced sharpener. The basic Apex + the slide guide, magnet, and bench mount is ~$250, I think. For a lot of people buying a clamped system may be a better way to go. They seem to be more expensive. However, I don't the cost matters as much because you're likely to spend far more on stones than the sharpener.
And you know... I was wrong about the bench mount being first. If you care about your edge angles (it's fine to not care), and angle cube is a must have. If you sharpen a lot of high vanadium steels, a good set of diamond stones is a must have. After those two, the bench mount would be first for me. So depending on your requirements it may be first.
For diamonds I can't recommend the EP diamond stones highly enough. They are a complete game changer in terms of speed of sharpening and edge quality. I have used the heck out of my stones. I've re-profiled at least 40 knives, probably over 50, most of them high vanadium steels, and I've sharpened hundreds of edges. They do show some wear, but just barely. Any concerns about sharping steels like Maxamet and K390 quickly disappear. Those steels become as easy to sharpen as any other steel.
How long ago did you get yours. I checked their website and they only have 2 grits on there.For diamonds I can't recommend the EP diamond stones highly enough.
cudgeeHow long ago did you get yours. I checked their website and they only have 2 grits on there.
I've had them at least two years, maybe closer to 3. I see all the diamond stones when I go to the EP site. It looks like I can add all of them to my shopping cart.How long ago did you get yours. I checked their website and they only have 2 grits on there.
Your question appears to exactly describe sharpening a knife like my Farid K2 (big belly swooping up almost vertically to tip/spine).Does anyone have tips on a knife that has a good size belly and swept tip? Cant seem to get the tip area very well sharpened without drastically changing the angle of the knife as I move the stone closer to the tip.
There is a sticky thread all about using the Edge Pro on the front page of this thread. Would be worth a read.Any tips on how to keep the bevel narrow or is that not possible with the EP Apex ?
Read through the whole thing before and not totally sure I understand it still. I think the width of the bevel is a factor of how thick the blade is behind the edge plus the dps sharpening angle. So thin angle means thin blade behind the edge. So theoretically, if I match the sharpening angle with the sharpee technique then I should maintain the thin bevel.There is a sticky thread all about using the Edge Pro on the front page of this thread. Would be worth a read.
You got the EdgePro diamond stones? This is not my experience at all. They cut quickly, particularly on steels with a lot of vanadium carbides. How are you leveling/cleaning them?Question on the diamond matrix stones. i was told when I ordered mine I needed them for harder steels. Used nothing but them for years and they make a perfect edge. They just take FOREVER, even right after leveling and cleaning. I recently bought their proprietary aluminum oxide stones and they remove material 3-4 times as fast on steels up to and including S35VN and Elmax. I dont even use the diamond matrix coarser than 1100 grit anymore. I use the 1100 and sometimes 2300 and 4000 just to finish up after the water stones do all the work. I know aluminum oxide isn’t supposed to work on the harder stuff so it was a hell of a surprise.
The bottom knife seems to have a very obvious burr on the edge. Or maybe something else is going on?View attachment 2442025
Relative sharpening newb here . Have EP apex with the magnet and adjustable 3 pronged blade table . Have sharpened s30v, D3V (CPK), and magnacut without many issues .
Recently sharpened my S45vN inkosi and had trouble getting it screaming sharp . The EP stock stones above 200 don’t seem to do much . I caved and bought EP diamond matrix 250, 650, and 950 . Assuming these are needed for S45vn, S35vn , and m390?
Haven’t attempted to sharpen the Shirogorov in the photo above (m390) but worried about the blade shape (Persian belly), the m390, and the really narrow bevel .
Yes. They’re Edge Pro diamond matrix. I have the EP leveling plate w both grits. The guy at Edge Pro, don’t think it’s Cody any more, sort of agreed with me. Talking about fixing a really messed up edge, he said he could remove steel faster with the 120 water stone than the 80 DIamond. Ive only had the water stones a few months but every time I use them I kick myself for not buying them years ago. Maybe I just got a bad batch of DM stones when I bought the kit.You got the EdgePro diamond stones? This is not my experience at all. They cut quickly, particularly on steels with a lot of vanadium carbides. How are you leveling/cleaning them?
If the AlOx stones are cutting faster the the diamond stones on S35VN there is an issues. Not clear yet what the issue is.
FYI the Edge Pro #120 is silicon carbide, a BORIDE Engineered Abrasives CS-HD specifically.I know aluminum oxide isn’t supposed to work on the harder stuff so it was a hell of a surprise.
Interesting. I haven't directly comparted the EP 120 (not even sure I have one) to the 80 grit diamond. My 80 grit diamond hogs off material quickly. I have reprofiled the edges on high vanadium steel knives at least 30x with it. I can try the 120 if I have it and do a comparison. Will report back once I can do that.Yes. They’re Edge Pro diamond matrix. I have the EP leveling plate w both grits. The guy at Edge Pro, don’t think it’s Cody any more, sort of agreed with me. Talking about fixing a really messed up edge, he said he could remove steel faster with the 120 water stone than the 80 DIamond. Ive only had the water stones a few months but every time I use them I kick myself for not buying them years ago. Maybe I just got a bad batch of DM stones when I bought the kit.
