Thanks for the follow up.
No pics in you #233 post :-(
How did you disassemble the slide holding the bearings? Those two screws on the end? Do you know the size if I need to add any?
I did clean everything multiple times and it does slide "OK".
And is this the video you're referring to"
777 Edge re bearings
Watch for my next post asking how to measure the angle correctly. I'm not sure if I have to measure the angle of the block that tightens the blade holder and add/subtract from the angle of the stone Or just use the angle of the stone. Obviously a total n00b here.
Not sure what is going on, if you click the X images it will bring you to imgur where the pictures will display. Do you even see the images that show a red X over a picture?
No need to zero on the table you system is on, has nothing to do with calculating the angle. As 777 Edge said, you zero on the system where it is in line with the clamps, then you put it on the back stone holder portion. Note: Some systems are different, you zero on the arm then measure the angle by the clamps, but this is because the clamps change angle instead of the arm.I knew that (not). My confusion stemmed from a YouTuber saying something like ... "zero the table your system is on, measure the angle of the 'angle cube' multiply by you social security number and subtract the winning Power Ball number, after which ..."
I really like simple. And this seems like a great tool to learn sharpening. Probably going to spring for your Gritomatic clamp system down the road.
Thanks again.
