$1,000.00...What would you buy?
I got the idea for this one from the Neo-Tribal Metalsmiths forum. If you had a $1,000.00 to spend on knifemaking equipment, what would you get?
As an added dimension to this I have a good sturdy bench under construction, a 6" vise, a 4 1/2" angle grinder, a 1/3 hp 4"x36" sander, a floor model drill press, an oxyacetlene set but no gas or oxy, an 8" bench grinder, a sway backed anvil but no forge, a flex shaft Dremel and assorted hand tools, bastard files and the like. What should I get if I had a $1,000.00?
These questions are deceptively simple, a grand can disappear real quick and isn't enough for any variable speed grinder setups
but is enough for a good single speed model, see what I mean! Thanks-Guy T.
ethier the JET 18" bandsaw, with 1.5" wide tri-master lenox blade, 1.5 tpi. or buy all the parts neccesary to build my 3"x132" belt grinder, and 40 zirconia belts.
Maybe a new grinder. Mine is ok but its hard to find good 4x36 belts. And I like hollow grinds better although I may not be very good at them. Or a new drill press, mine is an old craftsmen with sleeve bearings, that makes for a pretty loose spindle. If I got a drill press I'd probably get a milling table to go with it.
Or I could just get a used bridgeport, although that would be hard to find in the $1000 without it being really old and worn out.
A metal cutting bandsaw would be nice to.
Geez, if only I could come up with money as fast as ideas for what I would like to buy. Oh well, all of that would be nice to have. but I'm managing without it right now and its still alot of fun.
Fix it right the first time, use Baling Wire !
Lmao, Matt!!! The money never catches up with the ideas!!!!
<A HREF="http://www.nebsnow.com/L6steel
"Always" TARGET=_blank>http://www.nebsnow.com/L6steel
"Always</A> think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!"
IMO, as good a 2 x 72" belt grinder as you can find. Frankly, I'd save up another $500 and get a variable speed model. You have everything else you really need. A cheap saw would be nice, but I'd scrimp on the saw and go long on the belt grinder.
Jerry Hossom
www.hossom.com
I'd buy a Coote 2" X 72" grinder, w/10" contact wheel & small wheel attachment,($500), scrounge an old 1.5-2hp motor,($100),2",3",4",& 5" sheave($30), buncha belts ($100), couple 8" 3M scotchbrite wheels ($100), sandpaper ($50) & whatever's left ($120) in steel & handle material. Pick up aluminum cans for $$$ to send out for HT ;-)
OK,
Here it goes...... It's already starting to get warm in the afternoons here in FL! With $300 of the $1000, an AC unit for the shop is the MOST important thing I'm lacking right now!
Then I would probably spend the rest on Talonite and handle material
I've almost died the past two summers with just a fan in my shop. This year I WILL be cool
Neil
Blackwood Knives
More knives in stock soon!
http://www.geocities.com/Eureka/Meeting/5520/index.html
definetly buy the air conditioner, i know how tough it is to where a respirator, and grind in 105 degree weather.
