The S10 is the S10C model which is the customized version. Here is everything I could find on it from manufacturer
meet your everyday carry needs, OLIGHT brings you this high performance EDC type LED flashlight -- S10 Baton customized.
This compact designed S10 Baton customized belongs to the S series of Olight, with a max. 500lm output and a small side switch,
which is perfectly compatible with CR123A and RCR123 battery.
It is powered by the CREE XPL-W2 LED and designed for portability, durability, reliability, and innovation.
The longest run time reaches 15 days under "moonlight" mode, which is really your best choice for the household and outdoor use!
Olight S10 BATON customized EDC Flashlight Features.
Utilizing the newest CREE XPL-W2 LED, the highest output reaches 500 lumens;
Three adjustable brightness levels, can be changed "low-middle-high-low-middle-low" in cycle,
the moonlight mode can be accessed directly when the flashlight is off; double click the on/off button to activate strobe mode;
Equipped with auto memory function and a side switch, the total length is only 70.5mm;
With strong magnet at the tail, the flashlight can be attached vertically on any iron surface;
With a two-direction invertible pocket clip, easy and reliable for use;
Stainless steel head ring, can bear higher impaction;
Flat tail cap allows convenient tail standing;
High efficiency constant current drive circuit; perfectly compatible with CR123A and RCR123 battery;
Battery reverse polarity protection.
Dimensions
Length: 70.5mm (2.77")
Head Diameter: 23mm (0.91")
Tail Diameter: 21.6mm (0.85")
Weight: 42grams (1.48oz)(without battery)
Accessories
1X CR123A battery
1x lanyard
1x user manual
