• The rules for The Exchange can be found here. Please read and follow them. Stop using Paypal Friends & Family and follow our best practices to prevent getting ripped off or having a bad deal.
9" Executive Chef in explosion pattern steel. PRICE DROP.
Feedback: 18 / 0 / 0
Up for your consideration is this rather extravagant 9” chef knife. The pattern welding represents probably my most involved adventure yet in damascus steel. The constituent steels are 15n20 and CruForge V. The CruForge offers some definitely enhanced cutting performance- I can definitely feel that it's a vanadium bearing steel, when cutting. Very sharp.
The pattern itself is 6 bars of twist/counter-twisted “w's” giving a multi-bar explosion pattern, albeit with a fine resolution. The tip was shaped using the forge welded “bird's beak” technique, to give a handsome visual pattern flow and minimize pattern distortion. The heel was forged directly into the bolster- indeed it is possible to see the bottom two bars of the edge being dragged up into the bolster area, a clue to the shaping process.
The edge is more of the French profile, long and shallowly curved, as is the classic Sabatier-inspired handle shape. The grip is fastened with a domed nickel silver pin for a touch of class, and the wood itself is some quite nice stabilized redwood burl with lots of eyes.
Cutting edge: 8-7/8”
Total length: 13-7/8”
Total weight: 7.5 oz.
Edge before sharpening: .007”
Spine at bolster: .100”
Heel height: 1-7/8”
Asking price is $1200, NOW DROPPED TO $1000, which includes insured shipping to the U.S.A. For international rates, please inquire.
A picture is worth a thousand words... so here's several thousand word's worth, and a vid to boot! Thanks for checking it out.
[youtube]wpYNqfvkI6Y[/youtube]
You know it's an epic knife when you see $1200 and think, "why so cheap?" Stunning work Salem, that blade-flat to bolster transition is just perfection.
Fantastic work. That is a very refined design.
Dang, Salem!!! How did you get all of that stuff to stick together under the hammer? :D
I used Wonka's Grape Yumptious Dip for flux, got that from Nick Wheeler...
Sure makes the shop smell funny, though.
LOL. Huh? I ask because my one attempt to forge weld Cru Forge was less than successful and I still have like 200 pounds of he stuff.
Sorry, that was a reference to a joke in one of Nick's WIP threads from a while back...
Really though, I've just treated the CruV like I'd treat 1095 in pattern welding. That is to say, always grinding surfaces when re-stacking, and running pretty hot (2400-ish for welding.) I do a fair amount of the early drawing at welding heats, too. I've welded it just fine by hand, under my little giant with drawing dies, and in my press.
I've been welding it lately with a more reducing fire, and kerosene. Works fine for that. The initial stacks in the above knife were kero, before going to wet welding for the multibar stack.
What were the symptoms of it not welding well for you? I will say that it's stiffer than 15n20 at high heat, leading to difficulty in twisting without shearing.
The CruV will air harden a bit, but I've not had a billet split after cooling or anything, even without spheroidizing.
wow! This might be one of the few times I've been seriously tempted by a knife in this price range! very impressive
