- Mar 25, 2014
1. Well you stay the hell away from my mule sir! We aint havin that! -- You can use cow hide if you like. As for your mules, what happens inna barn, stays inna barn!
2. So the mule washer keeps the file in the shoe groove until you push it all through then its not really needed until you pull the reamer out entirely to add more paper shims if needed. -- Do not understand "shoe groove" you speak of. The washer merely applies pressure on the reamer & shoe which keeps the paper shim in place. The washer slides off the reamer as it enters the bore and rides on the shaft. When the reamer comes back out, you or a helper need to slide the washer back on.
3. You must reharden the file after filing the corners right? wont cut very well otherwise will it? -- YES!! The reamer gets reheat treated once it is welded onto the shaft.
4. Once you wear out one "corner" of the file you can put the shoe on another corner and keep cutting? I'm assuming that only one corner is cutting at a time.-- The reamer cuts both directions, thus two corners can do all the work. When the corners get dull, sliding a stone on the sides whets'em back up.
5. So if you still got pits or irregualarities that rifling wont get rid of and you reach your desired bore then your screwed? Am I even close?-- Usually not. In rare instances you might be.. All pits and irregularities are removed by boring. You might end up with a larger caliber than intended IF you didn't weld the barrel up properly. Theoretically, you can make any caliber barrel you want--as long as you have enough barrel wall thickness. But, if you're the guy who has welded & rifled more barrels than Colonial Williamsburg, Old Salem, Brad Emig all put together, then this issue probably won't rear it's ugly head. I have rifled more barrels by hand, with home grown wooden tools, and no electricity, than any man living. This IS one thing that I did actually write the book on. If you could find copies of one of my books and DVD on this, you might better understand what I'm trying to say about the processes. Want everyone to understand I'm not trying to toot my own horn and sell stuff on this forum.
6. Like I said before Damn your good! Your krazy kami That's what she USED to say to me....
