These look nice, tell us more! Steel? Forged? Hear treat? Philosophy?
Thanks buddy - I'd have written something then but it had already taken ages to get my phone and Imgur to play nicely together so I ran outa time for waffle
I work stock removal methods rather than forge.
The chef knife, which is not quite finished in the photos, is from 2.5mm thick Sandvik 14C28 hardened by a specialist to 61/62 HRC, which I then convex ground post heat treatment freehand on a basic 2x72 grinder with an added water feed. Handle scales are lightly spalted beech 'stick wood' I collected, seasoned and stabilised myself, with bolster detail in dyed, stabilised silver birch from the tree side of a burr/burl, liners are dyed leather, with copper sheet for aesthetics and to move the balance point to under the first handle pin. Pins are simple home made mosaic pins.
The next ones up are pretty much a miniaturised and edited 'Woodlore' pattern (with sharpening choil added) hence the 'wodlo' moniker (yeah I thought I was being cute). Steel for these is ~3mm 26C3/'Spicy White', and was again HT by a specialist, in this case to 63HRC before again wet grinding and sharpening on the 2x72 using ceramic and Trizact belts. These are very steep/sharp angles and the grinds all vary a little, as I wanted to find out what this steel was like at these edge angles, and also wanted to play with doing a bit of convex and mixed bevel grinding. Handle material silver birch burr with pale/white rot spalting that I collected, seasoned, dried and stabilised, the dark one and some of the bolster detail is of very dark spalted beech wood a friend sent me from his firewood pile, the other bolster material is blue resin with alder cone, and another piece of the multi-dyed, stabilised straightish grained birch burr end. Liners again are dyed (reclaimed) leather, simple home made 6mm mosaic pins and riveted lanyard tube. The tangs have been drilled and lightened beneath the scales.
The last bunch of knives are in 2.5mm 12C27M apart from the curved mushroom knife which is in 3mm. Bushcraft knives I had cut from sheet by laser to fill up a steel sheet I was having my first ever round of mushroom knives laser cut from about 6 years ago, and are half length tang but full tang style, hardened to appr. 58 HRC, and finished in some lovely reclaimed oak flooring wood, and one in dark blue clear resin with large cones and a blue dyed birchwood bolster piece that was cast in place with the block. Plain stainless pins on 2 of them, the other 2 have simple home made 6mm mosaic pins, and they all have 6mm riveted copper lanyard tubes.
The mushroom knife - I started making mushroom knives and have made and sold about 40 in total mostly quite fancy full tang ones, but the one in the photos is the second iteration of a much smaller stick tang design, and this one features blue glow resin in the bolster tube around the blade, handle is of some lovely grained ash I collected years ago, I chose a 5 or so inch round log of it, quarter split it turned to spindles and stabilised for the job, turned sections in a mushroom-ish shape on the lathe, and lanyard wire loop secured in the butt end with the cleaning brush.
I try to do as many of the processes involved as I can, which is tough as I have tiny crowded spaces only to work in and not much useful time to do it and I'm a pretty beat up 54 y/o with a knackered back and a mostly home schooled very hyperactive 7 year old lad heheh. I got a 3 burner gas forge for basic HT but I cannot replicate my HT guys results even nearly, and it isn't safe to run it in my workshop, so off to a knife HT specialist they go he's spent many years learning just this. All my casting and stabilising and wood sourcing I do myself - I refuse to buy wood, especially imported/exotics and my mission really started with my trying to show off the beauty in wood you could just find kicking around, if you treated it right and stabilised or resin cast it, there's a world of delight hidden inside especially once the spalting and decay have started to set in! My ethos is to make minimum negative impact, and even though I use resins and such that aren't biodegradable, I make all my stuff with the intent it lasts a lifetime.
I'm sure I left loads out but you're probably starting to be sorry you asked by now heheheh!
Cheers again!
Shaun/FloWolF
