Maybe I am stupid too, but is there something wrong with the Victorinox spring?While I'm no fan of scissors on a SAK, I keep wondering why Victorinox won't marry the Wenger spring design (which looks robust, unlike the Vic spring) with their own scissor blades.
Any thoughts?
A lot of people think it's fragile and prone to breaking because of the lower quality leaf springs found on other more cheaply made knives.Maybe I am stupid too, but is there something wrong with the Victorinox spring?
They break. They can also get bent out of shape.Maybe I am stupid too, but is there something wrong with the Victorinox spring?
Okay, I did not know that. Is there any pictures for educational purpose available? I am not really that big on scissors on my SAK´s, I prefer a saw over scissors, so my experience is limited. I am not sure how to interpret what you mean with "back spring of the knife"? Does it share spring with another tool? All Vic with scissors that I have have a designated spring (and do not share spring with another tool) that is just as strong as the blades spring...They break. They can also get bent out of shape.
The beauty of the Wenger design is, it uses the back spring of the knife as the scissor spring. I like it. I think it is the better design.
O.B.
O.B.
The same spring that holds the scissors open in their deployed position and causes them to snap back to their undeployed position is also the same spring which is used in order to provide tension for the scissor blades to return to their open position while in use. The piece of metal that contacts the hinged scissor arm is also contacting the back spring for the other arm. As you squeeze the scissors, this metal piece is being pushed against the back spring, which then creates tension, which then forces the scissor blades back to their open position. I hope that makes sense.I am not sure how to interpret what you mean with "back spring of the knife"?
The problem with this design is that it cause the other scissor arm to move away from whatever it is that you are cutting. This gives you a wiggle effect, where the scissors wiggle back and forth while you are cutting. This is a problem that is not present with a leaf spring design.
"Wengers wiggle" is how I always remember it.
