- Dec 10, 1998
From what I have discovered the upper pin, which keeps the blade in the center, and keeps it from hitting the channel wall only sees abuse when the knife is closed. Even if it stored closed , what kind of wear does it see while it is closed? When the knife is being opened the lower pins gets more force exerted on it including the weight and inertia of the other handle. The larger pin has a greater surface area distrubiting the forces exerted on it more uniformly. I would assume that someone using a bali would want a tight lockup when the knife is opened, making it safer and more sturdy. When it is closed the handles only function is to hide the blade. I recently made a new latch for a customer's pacific cutlery balisong, the old one had been broken off. The small 1/8in tang pins had over the years dug themselves into the handles and the blade lockup was not tight, it had play both open and closed. A smaller pin exerts more force on a smalled surface area, making where it hits wear out faster. A larger pin will wear out slower. It is also more asthetic when opened, the small pin then leads up to the large pin and then the handles.
I'm glad that this topic is turning into a great discussion.
Chuck
Chuck
