Since the forge welding temp is up around 2100F to 2200F, and copper melts <2,000F how do you keep the copper from being molten and running out from between layers of steel?It's a layer of Cu between layers of steel
It is forged
I had no idea copper could be forged welded with steel, but I'm no expert at forge welding at all. I've used nickel strips between layers of San Mai and Damascus, but the melting point of nickel is over 2600°F so that's pretty easy.you can forge weld at 1700-1800 degrees (even colder with a big enough press). There a good number of copper San Mai billets out there
I'd LOVE to forge weld some copper between layers of San Mai. That would look so good. If anybody can provide guidance on how to do it I'd love to try it.
The top one is a fighter with wrought iron welded to the blade using nickle foil and is more like the example i showed and the bottom is the copper wash that has been mentioned.I’ll take a shot. I’d love to see the image you are trying to post to get a better idea of what you are trying to achieve.
Sounds like you want to copper wash the nickel strip in the middle of a go Mai blade. I believe that’s done by a having a stack of say 1080/15n20/1080/15n20/1080 which should standard etch in diluted ferric Dark/Shinny/Dark per side when finished. Then you take another batch of diluted ferric with Copper soaking in it and etch your blade once again. The copper in the ferric should wash over the nickel layer. Leaving you with Dark/Copper/Dark per side.
I cannot find the images I’ve seen of this right now. Imagine the top knife with a copper stripe where the nickel is. The Damascus is a better example but a little busy compared to a go Mai blade.
Hope this helps, I’ve never done this before but I believe we are on the same page. I’ve seen pics out there and I like the look.
