I think magnacut is definitely punching above it’s weight here. At the end of the day, you’re talking about a steel with a carbide volume far lower than s110v and k390.
Still, this steel should have s35vn like edge retention (at 63 hrc) and be as tough as 4v, while being as corrosion resistant as Lc200n. That’s an incredible mix of properties, and should be enough to sell steel geeks on it as a balanced steel. Just don’t expect it to outperform the steels designed with wear resistance as a priority.
I think it's a safe bet that Spiderco skipped the 20dps step in their sharpening on the Mules, if I'm right we will see the Mule drop cutting ability from the factory edge when sharpened at 17 degrees per side.
If the Mule is an indication Spyderco would be willing to ship all MagnaCut knives at 15 degrees per side then it may as well be considered a miracle steel just for convincing manufacturers to change standard practice, but that won't impact enthusiasts, only average users who never re-profile a blade.
