Price is $300 $250 ea (shipped within CONUS).  If you live outside the US, I will contact you after your order for extra shipping charges.
XHP is a special/limited run, but it's not a KnifeCenter exclusive like the M390. They just happened to receive and list their shipment of CTS-XHP Gunnies before any other retailers did. (It seems like they're always the first or at least among the first to get new products in stock and listed for sale, regardless of whether it's HTM or other manufacturers).Older models were made from S30V. The S35VN is basically a slight upgrade to S30V.
M390 is a Knife Center special run. It's my favorite steel to date for the Gun Hammer--easy to sharpen, long edge retention, and takes a superb edge.
CTS-XHP was also a Knife Center special run, IIRC. I haven't tried anything in that steel, however.
Yeah, as far as I know S35VN will be the standard steel on HTM Gunhammers going forward.What about future Gun Hammers? Is the S30V a thing of the past?
In addition to the reasons Dirk mentioned, I know that for a while there were different steels on the automatic versus non-automatic (assisted and manual) HTM Gunhammers. The automatic versions of the HTM Gunhammer used 154CM, while the non-auto versions used S30V (and then later S35VN).Just got the April issue of Knives Illustrated and the back cover has an HTM ad showing 4 Gun Hammers. It lists the blade steel as 154CM.
I can't speak officially but, I know early on the original plan was to use 154CM or CPM154 as the standard. I don't know if that came to pass. It is possible the ad was made up from that old information and the steel wasn't changed in the ad.
Hi,CPM 3V
apologies for the confusion. I was typing on my iphone last night and was having a hell of a time keeping the quick reply portion centered. I meant CPM 3V.
Agreed. CPM-3V has developed a bit of an inflated reputation as a "super steel" due in large part to those destruction tests Brady at Monkey Edge to promote the 3V run of Strider DBs. However, CPM-3V's main strength is its incredible toughness (resistance to chipping/breaking/deformation), which you're really only getting the most out of when you use it on a fixed blade -- where prying, batoning, etc. come into the picture. 3V's wear resistance, by contrast, is decent but not anything special, being on a par with CPM-S30V/S35VN. In terms of wear resistance, something like S90V, especially run at 60+ HRC, will blow 3V out of the water. Bottom line is that given the typical uses, grinds, and blade lengths on folding knives such as the HTM Gunhammer, you're simply not getting as much out of 3V as you would out of something like S90V.Hi,
I don't know if you have had the chance to become familiar with Ankerson's Ranking of Steel thread over in the testing and review section, but if not, it is a great read. Long to be sure but well worth it. CPM3v I believe falls in cat 4 I seem to recall. Granted there are many things to consider, but in a folder CPMs90v beats it by a long shot in pure cutting tests. One reason some of us pushed hard for it in the forum knife and with the correct heat treat with a minimum HRC of 60, it placed easily in the top tier cat 1.
Cheers....
