Hi gents
I am using the
"Leading Edge" system designed by
777 Edge
and the
KakBritva side clamps available from Gritomatic.
It was very rewarding to assemble the system at home with 3D printed parts and in the process establish a friendship with its designer.
Burt has a wealth of knowledge on sharpening and was always happy to answer my many questions.
I sharpened the Bunny's pen blade at about 17 degrees ( on my second measurement it read a tad more at 17.4 but I left the system as it was)
The Bunny's pen blade is narrow and quite small so I was very happy with 17+ degrees.
I could see a bit of light under the stone so I could have gone lower if I wanted to.
My default angles in the initial reprofiling for all my knives are either 15 or 17 degrees per side (depending on steel, hardness, purpose etc)
The occasional maintenance is done on the sharpmaker rods at 20 degrees
A very few
LIGHT passes gets you screaming sharp again
( sort of a fancy way to stropp the blades I guess )
I know that on my Victorinox pen blade I can get about 15 degrees no problem
My lambsfoot could go to about 12 degrees
I had been on a quest to find a sharpening system and/or clamps that would allow me to sharpen pen blades at lower angles.
The Leading Edge system coupled with the KakBritva clamps solved it for me
The beauty of these very economical clamps is that they can work on many different sharpening systems by using the proper adaptors available from Gritomatic as well.
So if you like to sharpen pen blades at lower angles look into these clamps and the accompanying adaptors for your particular system
I had no issues sharpening near the choil. The stones hit the area quite well
I discuss the KakBritva clamps in my thread about the building of my Leading Edge system here:
If you're taking about the first pictures, that's my system printed in black with only the rotatable knife clamp, which is one of the many adapters to my system. It's not a mod, just part of my system. Do you mean the post with a drawing of an adjustable pivot bearing that can move in and out...
www.bladeforums.com
I have sharpened scissors and chisels on the system just to try all of its parts however my main interest is in small traditional knives.
I don't know about a bit axe head
afishhunter
. You can shoot a PM to
777 Edge
and ask him ... tell him you know
CelloDan
LOL
PS: further enquiries would perhaps be better addressed in the Maintenance section of our forum
Cheers
