- Jun 25, 2017
X
Goose Wing Handle by Agent Hierarchy, on Flickr
Wrong direction?
Chips and Balsa by Agent Hierarchy, on FlickrIt does doesn't it?Handle looks nice with the oil on it!
Lets start over with the handle: Just make a club in de required shape you want. I say club for a reason, so will come to that eventually. Lay the axe flat side down on a table. Now take said club and whack the shit out of it! Just kidding.
Now look at the the club in your hand and place it so that your knuckles are not touching the table. If you feel comfortable with a couple of mill go ahead. It's what I do. If you feel comfortable with an inch or more, go right ahead. It all comes down to your own preference. Most of these blades didn't have a handle when they where sold anyway.
You can now draw the triangle shape on it. If done correctly, your knuckles should not touch the table when you grab hold of the club. If done incorrectly they do. But no worries just yet: I said club didn't I?
Next up is shaping the handle:
If done correctly, take of the topside of the handle to thin it down. Mine is about 3/8 " but thats my preference, so yours can be a lot thicker if you like.
If done incorrectly take material out of the bottom of the handle. That way your knuckles are saved.
Coopers handle by Agent Hierarchy, on Flickr
I'm better part of the way through hanging your Plumb rafting head and have been experimenting with an octagon handle (flats) instead of oval. My initial feeling about this was that it's 'an easy way out' but now that it's mostly shaped I love the extra control (I've been field testing it!) and have decided not to round the corners in order to create an oval. Structurally there is more meat in an octagon then there is an oval of same dimensions, too.Good stuff, guys.
One thing I would add is that with any offset handle you create an off-balance situation that makes the axe want to twist in your hand. You have to apply some amount of constant force to counter that rotation. A round haft will be harder too apply this counter force to. A flatter handle will make it easier to counter the rotational force.
