I don't have a direct response to your thinking out loud, Broos. I too will engage in some of that:
From Test for measuring cut resistance of yarns, Hyung-Seop Shin, D. C. Erlick, D. A. Shockey:
The blade (Stanley utility blade, 2 um mean radius, 30 deg included) made one perpendicular cut through a yarn (made of 330 12-μm-diameter polybenzobisoxazole (PBO) fibers) of Zylon (a cut resistant material they were testing) material. The cut energy was 0.105 joule. Before the cut is completed, the edge deforms and expands to a radius greater than 5 um (evidenced by the fact that a harder ceramic blade of 5 um radius was outperforming it).
I think you can imagine what work even on this scale (1/10 of a J) directed at the edge not in line with the axis of the blade can do.
My personal feeling is that machine testing will be representative of good human testing. There will probably be a scalar factor, but I think the trends will be the same when comparing different steels (all other factors being the same).
I think it would be interesting to do a round robin assessment of hand testing versus machine testing. My hypothesis is that the larger the number of people testing by hand, the larger the deviation will become. This isn't saying it is bad testing or data. I think I would imply that without a "standard" results will vary and discriminating between results is very difficult.
Wayne,
I'd like to sit through your sharpening demonstration - hopefully I can someday. Reading back through your posts I read that you make a stroke or two at an increased angle to remove the wire edge. Could you explain how you tell that the wire edge is removed? Also thanks for your sense of humor - a couple of your early posts had me chuckling this morning.
My finish stone is the Norton Fine India (aluminum oxide).
Miss seeing you guys there in Happy Valley! Keep up the good work. Loved the forum as it recalled the 5 years of arguing the merits on whether this technology was worth the investment to pursue. Charles sent me a FF'd prototype 'personal defense' knife I could have used in my operational days. Truely a thing of beauty and much, much bigger than either Carls' or Tracy's.
Bravo Zulu
Cdr. "Augs" Flak, USN-retired
C is uniquely identified, but a and b can be traded off in a correlated way to get an acceptable fit. Since neither a nor b is a physical parameter of interest, but just a fit coefficient, it doesn't give me heartburn that there is a range of a and b values.
I suspect, but don't know, that treating a and b as independent may be where Cliff had some trouble with the fit parameters.
Unless the correlation coefficient is absolute zero, which is very rare, the other parameters can always compensate to some degree, that of course is the definition of that coefficient.
The method I used nor the computer I ran it on was not bothered about the results, neither had an emotional attachment, nor paused for an instant during the calcuations. They simple produced a result which showed the parameters were undefined as the data variance was too large due to the calculations performed on the raw data which magnified the data.
As noted clearly many times, the actual raw data was perfectly fit by the model, as is every set of edge retention data I have seen to date.
It would be interesting to see a FFD2 at 67 HRC vs CPM D2 at 64/65 HRC which will probably be done at a later date and ideally none of the testors will know which blade is which. Lots of other points of interest one as simple as just 1095 at 66 HRC vs FFD2 at 67 HRC to remove any hardness advantage and then check edge stability and long term slicing aggression (or just 1095 vs M2 at the same hardness). But that is months away, right now there will be lots of data of various types coming in with the Military and Sorg from various people doing various types of work. We will also get to see directly how the quantitative work done by Mike and Paul compares to the guys just using the knives in their work and hobbies.
