Brian Jones
Moderator
- Jan 17, 1999
Obviously, this question is highly dependent on terrain/climate, length of time in the woods, and other factors, such as how much gear you do or don't have.
What kind of emergency shelters do you prefer if you have to build mostly, or all, from natural materials?
I've found debris huts are good for survival in forested areas when you don't have much or any equipment (including not having a tent or a knife) -- but any of us who've built and slept in them knows they are not really anything comfortable, but at least they're life-giving. In cold climates (winter), you should have at least 3-4 feet of debris piled up. Warmer climates should have at least 2 feet of insulation, so it still keeps rain out in case it occurs. Pieces of moss or birch bark on top will help to act like shingles/roofing.
I've experiemnted with using my sleeping bag as the final layer between me and the scratchy branches and leaves. It's much more comfortable...but you can also catch and tear your bag if the surrounding debris is not soft enough. What other things would you use?
Cobb walls as a base is a good solution for longer-term stays -- shields you from cold lateral wind a lot more.
Grass huts are cool, but don't seem to protect against wind, and take longer to build (collecting and drying the grasses, etc.) -- so you have to be able to bundle yourself up inside them and have a good fire going. A debris wall around the outside might help...
Thoughts?
Brian.
Thoughts?
Brian.
