For years (I'm 64 now) I've carried traditional pocket knives. When I discovered Queen's D2 that put me into what many consider, the modern traditional knife.
My latest addition to the modern traditional is the Falkniven PC. I haven't had a chance to put it through it's paces yet but it should hold an edge right up there with the best of steels.
The first thing you notice is it's left & right handed, there is a nail nick on both sides of the blade. The nick is deeper than it needs to be because this knife is one of the smoothest opening knives I've seen. You can use the nail nick or pinch it open. Blade is centered & the lock up is perfect with no vertical play and no side to side play. There's a nice click as it closes to let you know it's locked. I didn't take it apart but the blade is held closed by a small bump/detent on the liner lock. You can feel a light bump as it rolls off the tang when you are opening it.
You can close it one handed, just press the liner lock with your thumb and roll it shut with your index finger. It came adjusted with just enough friction that you don't have to worry about the blade falling on your fingers.
Stainless steel liners are inletted in to the handle. The handle is fiberglass reinforced Grilon. Grilon is a high strength, high impact plastic.
The Falkniven PC came with a good working edge, smoother than most with no burrs. The edge was ground about 20 degrees per side, I re-profiled mine to 18 degrees per side. That might be a bit conservative to some but since I don't shave with a knife it will be a good working edge for my uses.
The PC has my favorite all purpose blade shape. If I could change one thing, it would be to thin the blade down from .120 to .100 thick.
You will not find this knife on youtube killing zombies, cutting tin cans, stabbing sidewalls, chopping trees, batoning what doesn't need batoned, prying open doors etc,etc.
On the other hand if you want a great EDC knife that you won't notice in your pocket, that can do all of the cutting chores most of us encounter, & then some. The Falkniven PC is a great bang for your buck.
One of my favorite design rules is the KISS principle (keep it simple stupid) and the PC holds to that rule very well. It's not fancy but it's extremely well made & should work equally well as a working knife or as a more casual knife.
Specifications
Total length: 174 mm (6.85")
Length folded: 100 mm (3,94")
Blade length: 73 mm (2.87")
Blade thickness: 3 mm (0.120")
Weight: 2.33 oz
Steel: Lam.CoS
Hardness: 60 HRC
Handle material: Grilon
Locking: Liner action
The Falkniven PC is the light for it's size, thickness is falls between the IRJ & Mini-Barrage.
Top to bottom, Benchmade Mini-Barrage 586 - 3.87oz., Falkniven PC 2.33oz., Northwoods IRJ 2.10oz.,
Specifications
Weight: 2.33 oz
Steel: Lam.CoS
Hardness: 60 HRC
