- Mar 6, 2024
My personal experience is that I use my CC4 dry because for me it's a portable pocket sharpener / honer / stropper, and I take one with me if I go somewhere for a little longer, or if I go where I know I might need a touch up or something. It's way more convenient for me to use the CC4 dry, because it's just simpler for me and you don't need to bring or make or requite water or oil or soap water. Every now and then I just clean the light side with not even a whole drop of Ballistol and something to wipe off that steel residue. The rough side I rarely ever need, but I used it a bunch a few times when I did some minor fixing, and it's still the same rough. Maybe they suggest to use ceramics dry because these stones don't need water or oil to function. But then people will do what they prefer anyways. Thinking about it, I didn't have to use my trusty 5k / 2k grit waterstone in a long time, which I only keep at home, but that's me.Which is frankly silly. I don't know why so many sellers of sintered stones suggest using them dry. Like, you CAN, but the way that sintered stones have limited ability to shed grit, if at all, means that using at least water on the stone, or even possibly oil, will reduce the wear to the surface grains so you don't end up glazing the stone from use. Sintered stones need periodic refreshing to keep them cutting instead of burnishing.
I started out on an oil stone when I was a young lad, and you really needed to create that paste with the residue that gets bonded in the oil. It's basically that fine-grained oil-paste that sharpens the edge and not the stone itself with oil stones; as far as my experience goes.
And I used my CC4 dry for a couple of years by now, and it hasn't glazed yet.
