Hey Ron,,Geoff....
Ghillie Suits...
Interersting topic...
Hords of different ways of making them...
I prefer a pull over suit to BDU's for a few reasons.. The first being BDUs can be a little to confined... Another reason,, you can't carry a Camel Back with it..
With a pull over you can have the option of tightening or loosening the suit in varoius places such as waist, chest, arms and feet.
In colder climates you maybe SOL if you have to wear several layers underneath,, but if they are Big,, you can always fit into them. A Hood on a Ghillie suit is a must! If not a hood at last some type of headgear...In hot climate,, it may be toooo hot.
A pull over also allows you to pack it in a ruck sack and deploy it quickly,, as well as peel it quickly... You have the option of wearing as much or as little underneath.
There are obvoiusly problems with both, the pull over being far more time consuming as a jacket and pants have to be patterned out and sewn together. Straps installed and all the other cool stuff that goes with it...
I like to use the same kind of mesh you find on the sides of baby play pens and pick them up every time I see them in the garbage! This material can also be bought at several places. Once it's dyed black small slits can be cut into it,, and the burlap can be tied on..
On to the burlap..
Definately frayed burlap is the way to go. It will break up the pattern of your body better,, and looks far more realistic than straight cut strips.
I've had a very hard time finding good quality burlap here in Canada..
About the only place I've found what I like is at a material store... I prefer the burlap to be a Very Tight weave with thin thread.
Old cotton bed linen can also be used after it is dyed,, although it tends to curl a little,, and doesn't fray very well...
I made a ghillie suit type cover for my duck hunting canoe,, that turned out excellent. I used large black patterns that looked like the shadows of a large tree branch with small clumps of green here and there. Another one I made for my ruck,, which was the same. A high degree of added camo...
Looking forward in seeing them in Ron's next viedo...
Ron lloking forward to yet another addition to my collection!
ttyle Eric....
Eric E. Noeldechen
On/Scene Tactical
http://www.mnsi.net/~nbtnoel
