I would lean towards saying pinched washers as well because it is super easy to do and it can result in a tighter stop pin making the blade hard to open (it can also result in the blade being a bit off center, which would obviously be more visibly apparent with a large than a small Seb.) In Tim's own video, at the very end when he closes the knife, it sounds like he may actually have a pinched washer as you can hear what sounds like the blade contacting the inside of the titanium handle...so it's pretty easy to do, and it can happen with both the sandwich method and CRK's method (I recommend using their method.)
What I have learned (from my own frustrations and failures) is that the secret to avoiding the pinched washers is to ensure that the pivot bushing is inserted in a way in which it protrudes enough on each end to 'grab' into the washers and then maintaining it in that position when reinserting the blade into the handle. The slight protrusions on each end of the pivot bushing then pulls the washers along as there is a ledge on each end to grab them. Depending on the Seb, sometimes it can take a while to find the sweet spot where the pivot bushing is 'wedged' inside in the blade in a way where free movement is restricted (if that makes sense...I am describing it terribly but effectively when the pivot bushing doesn't slide back and forth super easily it's then wedged in enough to stay in place and hold each washer so that it remains inside the bushing and doesn't wind up pinched between the end side of the bushing and the inside of the handle.)
Unfortunately, with a pinched washer, if you torque down very firmly, the soft nature of the washer mean that they can permanently deform under this load. When this happens, if the deformation is significant, the knife will not perform very well even if proper assembly follows. Severely pinched washers can be visibly seen, so you may wish to visually inspect them to make sure they are okay. This is a thread showing their looks -
https://www.bladeforums.com/threads/would-you-call-this-a-pinched-washer.1374310/
edit - I just took a Seb apart to take a picture. Here's a pinched washer job I did. This one is pretty minor in terms of impacts, so the knife hasn't been serviced, but it's not quite as smooth now as another small I have without one of these
