Complete blade. When you do spot hardening, you get a transition from hard to soft. You will inevitably get a kink (bend) at that transition.
One thing you can do is fully harden the knife, then do a differential temper (with a torch) to draw down the body a bit.
So a transition from hard to soft will give you a bent knife, but a transition from hard to slightly-less-hard will be fine.
