Am I the only one that losses posts with this software
After typing for an hour, my password and post both get lost and the "refresh" takes me to the login screen. Grrr
Anyway, get an
ABC class fire extinguisher. These will normally be listed as dry chemical.
The 5 pound models are a little larger around then a vegtable can but are easy to store underneath a kitchen sink.
Ever notice how slow water runs out of a faucet when you are trying to put out a fire? Then you have some water to throw on a grease fire or a wall/exhaust hood fire? Try to smother a skillet fire with a lid or ABC fire extinuisher.
For utility closets (furnace, water heaters, etc.) or garages, get one of the bigger ABC dry chemical models you see at work. You will want more volume (run time), the wider spray pattern and, the reach (distance).
If you need the fire extinguisher bad enough to pull the pin, do it after the the Fire Department has been called. Fight the fire, if it's safe to do so, while they are on their way.
Have you ever rolled out of bed at night (moonless night, no night lights) and tried to crawl out of your house? I know it sound silly but, add panic, fear, smoke and, confusion and it ain't easy. Five minutes of practice could save your life.
When you stay at a hotel, do you know whether to crawl right or left? How many doorways will you feel before you hit the fire escape? What do you do if the door or handle is hot?
My rant about candles and halogen floor standing lights:
Don't let children burn candles in their bedrooms! Teenage Girls are typically burning scented candles when a bedroom fire occurs. If they must burn candles, make darn sure they have a good candle holder. One that won't tip but, if it does protects the flame and heat from whatever it lands on. Finishes on furniture typically light very easily. That stuff that
makes it shine like new will also make it burn quickly (flash) burn the bedroom fast. In 5 minutes, you will be looking at nothing but charred wall studs and piles of ash where clothes, pictures, etc. used to be.
5 minutes is all it takes.
Floor Standing Halogens will light a fire in a heartbeat if it is tipped over or gets a curtain close to it.
Keep them away from children!
Only you can prevent fires! Only fight them if it is safe for you to do so.
