While Edge Pro is the most precise manual sharpening system out there, they are not the fastest nor the most durable because they use silicon carbide and aluminum oxide stones instead of diamond. Diamond is the hardest natural substance, and at the same grit it will outrun and outlast carbides. When you intend to reprofile, experienced Edge Pro users will tell you to get one more coarse stone right away because it doesn't seem to last very long.
I've heard rumors saying that Edge Pro is gonna sell diamond stones, but so far I only see one "super fine" diamond stone on their website.
If only Edge Pro collaborates with DMT, we would have a perfect sharpening system. Since they don't, I'm sticking with DMT.
The Edge Pro is faster then the little gizmos even with with diamond stones like the guided DMT setup because of the length of the stroke on the EP and the amount of pressure you apply with the coarse stone. The only competition in a guided system in speed might be when using full size DMT's with the guide on the bench and a D8XX plate.
The 120# EP stone is very fast IMO. Quite a bit faster then my D8X free hand when re-profiling, but not as fast as a D8XX which is also quit a bit faster then any of the DMT's with the little guided rods. However, the scratches from the 120# water stone are much finer then a D8XX leaves (or even the D8X for that matter).
I don't think you are going to see EP offer coarser diamond stones. Ben Dale tried diamond stones with the EP a while back, but had the diamonds strip out of the nickle plating that holds them in and ruin the plates in short order. Probably do to using excessive force but he stopped offering them. The fine ones are for sharpening ceramic blades and he doesn't recommend diamond plates for steel with the EP. If you want to use DMT plates on the EP you could mount your own or call him and talk about it. Maybe you could sell him on it. He is very responsive and good about answering questions on the phone. Ben Dale at EP 541-387-2222.
It is true that diamond plates don't dish and last a long time, but the diamonds do wear, break, and more importantly come out of the relatively soft nickle platting that holds them in and eventually this leaves the plate useless so they have a life they just don't require the maintenance of a water stone. The wear of a water stone keeps fresh grit exposed and unclogged so the grit is consistent. Diamonds change as they wear. They need a break in to knock off the hi flyers (if you care) when new and then get finer and slower as they wear. For those that like to work the scratches out with small steps in grit this can be an issue.
Dishing of the 120# stone for me has been more of an issue after reprofiling a lot of knives. I would say after 10 - 20 or so knives I would lap and flatten the stone. They last a lot longer then they would free hand because the EP has a little plate that you adjust to be even with the edge of the stone that lets you slide on and off the stone with each stroke allowing you to use the full length of the stone with each stroke and not wearing the center as quickly. Also, remember you only use the 120# stone for reprofiling or some other really heavy stuff.
I like to have two of the 120# stone around so I don't have to stop and lap if I decide the stone is to dished. I haven't worn on out yet though.
Gary
