When he first posted this thread, Ted had asked me to get Chris to look over the details just to make sure that everything was correct. I have to apologize that it has taken us so long we had some vacation days, then we had company and all of this seems to make the days evaporate. Yesterday, I had the post ready to submit was just organizing the photos and I lost everything I had written (I have still not managed to get much beyond just barely capable with my computer!
). Here is another try today!
Ted, you have done a fantastic job on this thread informative, clear and well presented. Thank you!
Chris has made just a couple of comments:
When disassembling a Sebenza, undo the pivot screw, remove it and the pin and then slide the blade out. You can see the pressure on Chris' thumb as he is pushing the blade left.
Set the blade aside, then undo and remove the other two screws and pins. This way is a little safer and overall its a bit easier.
Concerning lubricants we absolutely recommend our Fluorinated Grease. This is not because we want to sell more of it
but because it fits best with our tolerances. Other types are either to thin and they dissipate too readily or they are too thick and offer too much resistance.
When lubricating the blade, in addition to both sides of the surface of the blade around the pivot hole, also sparingly put lube inside the hole and on the flat of the blade against which the locking bar seats when the knife is open.
There is no need to put lube between the washers and the handle, nor is it necessary to do any super special polishing of the washers. Just make sure they are clean (rub them flat on a piece of paper towel to remove existing lube and any dirt that may be sticking to them) you dont want to get into a situation where you have altered the thickness of the washer because you are going to get problems with side play.
Teds description of the assembly is 100%.
Thanks for your patience everyone - and enjoy!!
Anne
