Hi all, I got some cool hybrid scales that have clear resin with stuff cast inside, just like the ones on this knife: https://www.instagram.com/p/BT8-M0ElCcA/
This maker says this knife is more towards art knife than hard user, which makes sense if the clear resin scuffs easy. There's G10 liner underneath the hybrid scales, and since the resin is clear, you can see the surfaces were probably not scuffed or sanded as prep for epoxying together.
My question is how best to use this material? I want to use it on a kitchen knife. Would I have to sand the inner surface to high grit, basically to a polished state, to avoid a schmutzy look appearing under the clear resin? And if so, would these hold up with epoxy only (which is all I've used so far) in the kitchen? I've never peened pins or used mechanical fasteners before.
