- Jan 9, 2011
I have had a few questions on sharpening Titanium and thought I'd go over a simple and cheap way to sharpen it. It sharpens up very quickly this way and a few dollars worth of sandpaper will keep it sharp for a long time. Most stones will clog so I'd avoid them... diamond is reported to work very well but I haven't tried it yet on Ti.
Get a pack of wet/dry silicon carbide paper (the black stuff), it is easy to find at any hardware, automotive or large grocery store. I think something like 400 will work to maintain or work up an edge.
Take the paper and cut off a piece, put it on a flat surface where it will stay in place and sharpen away! It is that easy. Your kitchen countertop will probably do the trick. Use a piece of heavy duty leather or even a mouse pad behind the paper for a convexed edge. A rectangular piece of glass or flat wood and sprayglue to attach the paper makes a nice setup.
You could start at 220-320 if it is far from sharp but it sharpens quickly in my opinion. If you want you can work your way up to 2000 grit but I wouldn't recommend it, Titanium cuts better with a toothy edge in my opinion. play around with the grits to see what you like.
Try to keep the burr to a minimum, they are tough to remove. Never use your nice leather strop to remove a Titanium burr, it will contaminate the strop. I like to do an ultra light pass on the paper to remove the burr if the burr is large, usually enough to loosen it up is enough then a few passes through wood will remove it. If you didn't build up a huge burr just slice through some wood and you should be good to go!
