Of course a mora is not as tough as a fallkniven, but a fallkniven is not 25 times tougher, but hey maybe it is. Pitdogs point is, is that extra bit of security you feel in a survival situation worth the extra money? I have never batoned myself but in a survival situation, if I was building a good sized shelter, there would be lots of times I would rather use either a good saw or a tougher blade then a mora.
However, I would be able to make do if all I had was the mora, just using a bit more caution. Pitdog and others would simply rather not bother with caution, they want their knife to cut what they want to cut, or baton, or chop. I think I fall somewhere in the middle of these two pretty distinct camps. (ie, the mora fits the bill there, small size but tough)
Liam
My point was that if you are tired or otherwise impared you may not notice things like improper technique. Not that I wouldn't bother with caution. The time we may need to depend on a tool for survival may be the same time that we are not at our best mentally.
Another example would be that I would not like to depend on a $10 "campers axe" of dubious quality in a survival situation although in a campground it may suffice. With careful use it may work fine however once again if tired or impared by such things as early stages of hypothermia a missed swing or whatever could result in a broken axe. Yes the same could happen with a good quality axe but it is less likely.
If given the choice between batoning and using a saw or axe/hatchet I wouldn't be batoning.
