- Jun 15, 2006
BL, do you by any chance have the website contact info if there is any?
Well one day I as feeling froggy and I tried to use my Korean knife to chop off a chunk of frozen pork. The edge shattered like a piece of glass! So that Korean knife went to the garbage.
Good to know Blue, I can see why that blade would be more for slicing dicing and that sort of work. Interesting it shattered you say? Did it shatter like metal that had been hardened too much for the task you tried or more like it was too weak a steel for the task? If you understand what I am trying to say?
Bigbore, working in Alaska I witnessed guides doing the same work on Grizzlies and large Elk, the choice of rock makes all the difference
But yes, knowing what you are doing with the knife DOES make a world of difference, still most of the guides I know these days use Havalon Pirantas or Baracutas. They just swap out the blade when one gets dull, it is actually faster than keeping a good blade sharp and they have replacement blades in all sorts of shapes depending on your anticipated tasks.
That Havalon Hydra is actually a well balances knife for the fact that it has two ends. As I said, being able to swap blade profiles for the task is pretty awesome. Adding the ability to use any of the Piranta OR Baracuta blade faces means you have a whole lot of function to choose from. Pretty much my hunting set plus 6 or 7 other options in 1 knife. One thing I will say before you decide. It means changing HOW you skin. No hard twisting chopping. You have to slit smoothly through everything. Otherwise you will break the blade. And even though they are pretty cheap you don't want to throw them away without getting your moneys worth out of them. So if you are a patient person who can keep the job steady and smooth I think you will love the Havalon blades. If you tend to chop through joints ect and don't want to change your style then maybe Havalon isn't the right knife for you.
